JMB RetrofitsSky Insurance
Results 1 to 25 of 25
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Opinions on Boost and Fuel Pressure Gauges - S3 8P
    Guys,
    I am now running Revo Stage 2+ with my 8P S3. I am the kind of guy that likes to know what is going on with my car on a regular basis and now that the car is pretty well tuned, it makes me want to know these things a little more urgently!
    So, I am considering installing an OSIR mount (pictured below) and fitting a Fuel Pressure gauge and Boost gauge.
    What are your opinions?
    Where is the best place to get OSIR stuff? Them direct? I do not think I would want the carbon fibre one as I do not have any CF in my car and do not plan to have any either (Don't think it suits sprint blue)
    Also, this one is only $60 plus delivery compared to $100 plus delivery.
    What gauges are required to match the orange lighting of the Audi?
    How difficult are they to wire up?
    warren_S5's Avatar
    Oct 2007
    7,163
    Hi Boydie.
    I used to have an Autometer Utralite silver / orange Boost-Vac gauge in my Leon (30PSI), and to be honest it was the greatest tool for keeping an eye on the health of your car. Cars pushing bigger boost carry much more risk when things go awry, and once I had a boost leak which was causing 28psi boost spikes which if I'd not known would have gone unchecked and maybe caused a catastrophic failure.
    I didn't put one in the S3 as I couldn't find one I liked. There is the Newsouth ones from Awesome which sit ontop of the centre column of the steering column (behind wheel), and then the vent gauges. but I do like the look of that one.
    Defi gauges are commonly used, but expensive.
    Getting through the bulkhead can be a pain in the arse, and you may/will need to drop the glovebox which has associated dashboard light hazards (airbag), and isn't always a pretty job. If you have a Forge DV, you should already have a tap for the boost.
    Look forward to seeing which route you go, but I'm liking the OSIR pod, very nice.
    Audi S5 3.0V6T Coupe Black Edition
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Cheers warren - yeah the OSIR is the nicest of the lot. Looks OEMish and I am not a fan of the steering column or pod gauges in the vents as I like symmetry and my air vents lol
    Defi do seem to be the best for both performance and aesthetics but as you said, pricey!
    Bulk head shouldn't be a problem, there is a panel below the the window wiper scuttle behind the steering wheel which allows access to the cabin from the engine. I have the DV so fitting kit won't be a problem.
    What about powering the gauges? Do you need a control box or anything to "tap" into the car like vagcom to monitor pressures?
    Dec 2009
    166
    Stick with podi gauges :-) I've used ns, ej, awe.
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Have you pictures?
    I honestly do not want the pods up on the steering column.
    I think they look best below the climate control unit and when coupled together with the non smoking pack allows more space beneath.
    warren_S5's Avatar
    Oct 2007
    7,163
    Work well in VW, but will blue lights work so well in Audi? Can you change the bulb colours like in autometer gauges?
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    There is just something "sexy" about Defi's though....
    Sep 2010
    117
    Is there easy access to the cabin from behind the wheel then?
    quattro81's Avatar
    All the gear.. No idea
    Feb 2011
    Kent
    982
    I had defi gauges in my TT... You need a defi link to run them, and that too is pricey.. You can get the Osir pod from the TTshop...
    Audi TT Interior Accessories for your TT Coupe or Roadster - Audi TT Coupe and Audi TT Roadster Parts, Accessories, Styling and Performance Tuning
    Red is the colour..
    Sep 2010
    117
    Some guff on that TTshop
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Quote Originally Posted by glasgowal View Post
    Yeah, there is a rectangular panel under the scuttle panel behind the steering wheel which you can gain access to the cabin from the engine area. It is just a blank plate for LHD cars (I think it has to do with the aircon system).
    JamesS4cab's Avatar
    Mar 2008
    1,122
    You have seen mine Andrew but if you dont like vent gauges, then mine arent for you!!
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Yeah James sorry, just not my thing but you never know.
    Are you getting enough air past the gauge to hit you?
    Hard to wire?
    What do you wire too?
    What gauge is it? Boost?
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Boost gauge, easy to wire, I used a 60mm gauge so it fills the gauge completely but if you use the 54mm gauge, you get a fairly decent airflow apparently.
    See my post on the "other" site.
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Wild prices for Defi...
    Boost:
    Defi Red Racer 2 1/16" Boost Gauge [DF06502]
    Is this the right one for Fuel Pressure?
    Defi Red Racer 2 1/16" Pressure Gauge [DF06602]
    Dec 2009
    166
    Podi makes for audi and vw color way. Just check it out. Defi is not worth.
    Podi.ca | Gauge solutions for Audi and VW
    U need to use it with either NS pod column, osir vent pod, or thermal one.
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    226
    Hi.
    Good topic.
    Have you looked at Stack?
    STACK 52mm Auxiliary Gauges: Pro-Control
    This is top quality gears.
    Sep 2010
    117
    Quote Originally Posted by Boydie View Post
    Thanks for the info!
    Quote Originally Posted by JamesS4cab View Post
    I just ordered one of these...
    PROSPORT - SMOKED SUPER WHITE BOOST GAUGE KIT - PSI | eBay
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Quote Originally Posted by A3SBQ View Post
    Hi.
    Good topic.
    They do look good I have to say! Will check them out!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    Have a look at these as well.... NewSouth Performance
    I had one of these fitted to mine...easy to install,easy to fit and different colours available.
    Awesome GTi stock them.....
    quattro81's Avatar
    Feb 2011
    Kent
    982
    Boydie, I had defi in my TT.. They match perfectly with the Audi clocks/interior if you go for the BF series in White with the red needle.. They really are second to none, you get what you pay for. The on off sequence they do is very cool, plus they sit there black when off.. I've been trying to find some pics I had of mine on my old computer.. I had fuel pressure and boost gauge in the Osir mantis pod ( the one you posted the picture of).. I've seen a lot of gauges in various cars, and defi were streets ahead in terms of quality.. The speed and accuracy of the needle because of the defi link makes them awesome compared to other more reasonably priced gauges I've had before! Lol.. Each to their own, though......?
    Here's a vid of thestartsequence for the bf range Defi Link-Meter BF - YouTube
    Red is the colour..
    Sep 2010
    117
    Cool gauges but they are like £150 each...
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Quote Originally Posted by quattro 1981 View Post
    Thanks very much for that mate, I do agree, Defi do look the best and that is what I am after but the price is crazy! Do you have to buy a control module as well?
    Who fitted your gauges?
    Did you have bother because of Audi Canbus system?
    See email below from Tein:
    Hi Andrew
    Thanks for the mail.
    We have products in stock which will meet your requirements, I
    can recommend parts for you, but I feel that it is best that you
    contact one of our VAG specialists for advice on fitting.
    VAG use a CAN BUS system that may not be compatible with the Defi
    product. By contacting one of the specialists, who are involved
    in fitting these parts, they can confirm whether or not you will
    face a compatibility issue.
    For Fuel Pressure and Turbo, we can supply 2 different types of
    gauges.
    The items we carry in stock are controlled by a central unit.
    DF07701 is the Advanced Control Unit.
    List price for this is GBP126.00 + vat.
    All sensors are connected to this instrument and allows you to
    set warning alarms, hold peak outputs and replay up to 3 mins
    worth of gauge readings following a run.
    The outputs are then daisy chained from gauge to gauge.
    We can supply either 52mm or 60mm clear screen gauges (Advanced
    CR)
    Defi-Link Meter ADVANCE CR | Defi | Product || TEIN UK LIMITED
    Or 60mm only black screened gauges (Advanced Black Face - BF)
    Defi-Link Meter ADVANCE BF | Defi | Product || TEIN UK LIMITED
    Feature of CR gauges - 2 colour selectable illumination.
    Feature of BF gauges - screen blacks out when ignition is off.
    For pricing, please follow this link
    Advance System|Gauge | Defi | Product || TEIN UK LIMITED
    For VAG dealers who have experience in fitting Defi, please see
    links below.
    JBS Autodesigns
    JBS Auto Designs - Audi / VW / Skoda / Seat / Porsche Performance Specialists
    The TT Shop
    Please contact them for advice on fitting Defi items and if you
    have an enquiry about a particular product range, they will
    surely contact me.
    Kind regards
    Chris Marshall-Dowe
    Sales
    TEIN UK LIMITED
    Unit 7 Avant Business Centre
    Denbigh West Industrial Estate
    Milton Keynes MK1 1DL
    United Kingdom
    TEL +44 (0) 1908 632861
    FAX +44 (0) 1908 375761
    Email sales@tein.co.uk
    quattro81's Avatar
    Feb 2011
    Kent
    982
    I had a mate of mine who used to own a motorsport shop fit them for me, and yes you need the defi advance bf control, which is like the central control unit for the gauges.. Then you can add whatever gauges you need to it, and defi do just about all of them.. I got mine from tein myself, although it was a couple of years ago. I don't remember any problems, but I didn't fit them!! It was on a 2002 TT, so might be slightly different? They did cost a fortune tho lol.. The control unit was like £300 on it's own when I bought it...
    Red is the colour..
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Thanks mate - think this will be a long term thing so I may trawl ebay and see what comes up!
