Ignition feed ?
fordfitzsimmons
NULL
Hi
I am looking to see if anyone knows how I would get an ignition feed for my air ride. I think the fuses are 1-11? is this in the fuse box under the bonnet or under steering wheel? And how do you open and wire into them? Hopes e can help :)
Car is 2011 3door
Pretty sure there are empty ignition feeds at the fusebox at the end of the dash - if you can't find one though I'm sure someone more knowledgeable will be along shortly!
Yeap fuses 1-11 on drivers side end of dash behind removable cover are ignition switched, grab a spare unused 1, sorted.
You have to remove the rear cover, unscrew the 2 bolts to twist fusebox round & push the internal pink plastic bit downward iirc to allow release of existing fuse wires with the correct tools or to push in a new repair wire.
Caution, dont add to an existing fuse unless its over rated, try to add a new fuse position.
451
610
26
2K
400
