    Apr 2010
    St Albans/Herts
    227
    8P C-pillar trim removal
    Hi,
    Can anyone offer any advice on removing the interior c-pillar trim? My version of elsawin doesn't seem to want to let me look at the A3 manuals.
    Thanks,
    Adrian
    '07 Phantom Black S3
    Superchips Bluefin Stage 1
    TTRS FBMFSW
    MY11 Rear Lights
    Auto-lights/Auto-Wipers/Auto-dimming rear view mirror/CHLH retrofit
    rickyquicky's Avatar
    Dec 2008
    London
    340
    Quote Originally Posted by ADi Nuff Valves View Post
    Hi,
    Thanks,
    Adrian
    C-pillars are at the back right?
    Never done it, but removal should roughly be like this, I may have missed a few bits:
    - Remove parcel shelf
    - Use torx screwdriver to remove the plastic trim either side of where parcel shelf sat, think there are 2 per side.
    - Unclip c pillar from where it meets the roof lining at the top
    - I cant remember if the tailgate rubber seal goes over the back of the trim, if it does, pull it off.
    - Give it a good yank from both sides!
    You may not need to completely remove the 2 trims either side of parcel shelf...if you do, there is a screw cover at the top at the back of the each rear door card. If you pop this off and unscrew the torx underneath, you will have enough space to pull the trims off.
    Apr 2010
    St Albans/Herts
    227
    Yeah they're at the back. Thanks for the reply. Doesn't sound too bad. I had the entire roof lining out of my old mk4 Golf so just a c-pillar shouldn't be too hard. Just wondered if there were any particularly tricky bits before I start.
    TTRS FBMFSW
    MY11 Rear Lights
