JMB RetrofitsAH Fabrications
Results 1 to 8 of 8
    Arnie's Avatar
    Jul 2011
    London
    166
    Audi A3 3.2 Dsg Flashing PRNDS
    I have drove to MOT garage today and everything was fine. After it faild MOT (not working rear belt - got stuck only - and split velocity gaiter - £70 fix) on the way home I got my DSG gearbox flashing. All gears PRNDS are flashing and it doesnt show what mode DSG is in.
    When moved to P it is back to normal, then to D or S is ok but after 10s it flashes again.
    I have managed to read error code 00194
    Anyone has got any ideas whats the problem? I read online that flashing DSG is mechatronic issue but car drives without any issues.
    Confused :S
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Could be raft of things, does it change up and down on the paddles and manual with the stick ?
    00194 - Ignition Key Removal Lock: Implausible Signal
    Possible Causes
    • Communication Failure with Gear Selector Module
    • Selector Lever (E313) faulty
    • Tiptronic Buttons (F189) in Selector Lever (E313) faulty
    Possible Solutions
    • Check Communication with Gear Selector Module
    • Check Selector Lever (E313)
      • Check Measuring Value Block (MVB) in Transmission Control Module
    • Check Tiptronic Buttons (F189) in Selector Lever (E313)
    Special Notes
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,389
    Maybe this will help?
    2004 A3 2.0 TDI DSG
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
    27,075
    The gear unit has a little microswitch which the lever sits over when in P, this can go faulty sometimes due to dirt, dust etc, so makes car think its in P even though its in drive modes, so cluster etc gets very confused & starts to flash, best to remove the gear surround trim, stick it in S with car not started of course, so you have access to the P position area, then push the microswitch down a few hundred times to see if that helps to clear any crap, see if it clears the problem, did for me.
    Flashing gears in dis are also inherrant of a dsg module issue, but atm I dont think this is your problem & only worry when gear changes & use show problems.
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Warning
    Old thread revival
    This sounds like my problem I have just started getting when moving from manual + & - to d my dis starts to flash but when in manual it drives and changes fine also the paddles work fine. The micro switch is this replaceable on its own.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    27,075
    No.
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    No the micro switch can't be replaced on its own or just plain No. Lol.
    27,075
    Well you only asked 1 question mate, so thats a No answer lol.
