JMB RetrofitsChris Nott
    Apr 2011
    19
    Early A3 170 CR - CBBB Engine Code - Oil Pump Drive Shaft
    Hi All,
    There's been some noise over on the Briskoda forum that some of the early VAG CR engines used the 77mm hexagonal oil pump drive shaft that was fitted to some of the PD engines and prone to rounding off, resulting in lack of oil circulation and overheating and subsequent seizure of Turbo / Engine.
    Later CR engines were manufactured with a 100mm oil pump drive shaft and had a different engine code and weren't affected. I'm looking at a a car with an early 170 CR engine (58 plate) with an engine code of CBBB, but this uses the ill fated 77mm drive shaft fitted which is prone to being rounded off.
    Just wondered if anyone on here has heard of any similar issues with the early CR engines?
    Cheers,
    Craig
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,129
    If it goes is it engine out job?
    Apr 2011
    19
    From the comments on there thats the way it looks. There's a gradual drop in oil pressure as the hex shaft wears until eventually it loses all oil pressure and its often new engine and turbo time!
