Chris NottJMB Retrofits
Results 1 to 14 of 14
    May 2006
    WEST YORKSHIRE, UK
    12
    MULTIFUCTION STEERING WHEEL UPGRADE?
    Hi,
    New to the forum and need a quick question answered from the guys that know how..
    I've purchased a 3 spoke MFSW (Vol & phone control etc) and would like to upgrade my existing 3 spoke steering wheel which doesn't have Multifunction. Just wondering is it a simple straight swap or would i need additional wiring for the Multifunction buttons to work or any coding to be carried out?
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    You will need to find out if you have the correct controller fitted that supports the MFSW. This can be done quickly with VCDS (it'll tell you the part number of the SCCM). If you have the correct module, then its a straight swap then a 5 minute VCDS recoding session. If your module doesn't support MFSW, then you must buy one that does, this then has to be coded in, then your wheel fitted and coded in. If you PM NHN (Nige) on here, he'll be able to do the job for you if you don't feel comfortable tackling it yourself.
    I think the part number of the High Line controller (which will support MFSW, Cruise Control and DIS), is; 8P0 953 549 F. There may be other modules that will work with your car but Nige (NHN) will keep you right.
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    wez3570's Avatar
    Jan 2011
    711
    If you have a highline DIS and DSG paddles, you should be ok.
    Ben @ Shark Performance fitted my MFSW and cruise control.
    Nice guy and great service at an excellent price!
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    V Maxx plus coilovers
    Speedlines- anthricite
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    For Sale Genuine Audi phone cradle (iPhone 4S/4)
    May 2006
    WEST YORKSHIRE, UK
    12
    Thanks for your comments.
    I have cruise control and DIS (which I'm assuming is the red driver information bit in the centre of the instrument cluster which gives info such as range, MPG etc) fitted as standard.
    Forgot to add it's a A3 2006 '55' 2.0TDI if that's helps with anything.
    wez3570's Avatar
    Jan 2011
    711
    Quote Originally Posted by H17E5H View Post
    Is your car manual? If so, you will prob still need to upgrade the ecu to one that accepts functions from the steering wheel.
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    If you've got cruise and DIS already, then it'll go straight on and code up. Easy job
    Suzuki GSX-R 750 K5
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by gary3306 View Post
    Gary, not sure that's quite right mate !
    I didn't have either cruise or mfsw on my car but I did have the 'highline' DIS. When I fitted cruise all I needed was the new stalk and surround and it worked fine. However, when I fitted mfsw the steering ecu that supported cc did not support mfsw. CC only requires a 'midline' ecu whereas mfsw requires 'highline'.
    This Ross-tech list, although quoting VW part numbers gives you the idea ! :- Steering Wheel Control Module Versions - Ross-Tech Wiki
    May 2006
    WEST YORKSHIRE, UK
    12
    I've checked the software version via VCDS and this is what ive got:
    Address 16: Steering Wheel
    Part No SW: 8P0 953 549 E HW: 8P0 953 549 E
    Coding: 0000042
    The part no for the MFSW is 4F0 419 091T 8UD. MFSW has volume control, phone control and paddle shifts.
    Does my vehicle support this or would i have to buy additional hardware?
    A3 8P 2006 '55' 2.0 TDI 140 6speed Manual.
    Fossie
    Rhubarb Triangle
    3,969
    Paddle shifts ? Don't remember you saying it was a DSG !
    If you already have paddle shifts then you should be ok.
    If it's manual then you need steering control unit revision F. You also need a new airbag wiring harness unless it came with the wheel.
    Unfortunately there is no guarantee that your existing airbag will fit the new wheel - they are not all the same. If you are unlucky then I have a mfsw without paddles for sale.
    wez3570's Avatar
    Jan 2011
    711
    Mike, I think he's saying the wheel he's bought has paddles, check his sig, manual 6sp.
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    Fossie
    Rhubarb Triangle
    3,969
    Cheers Wez - just noticed that and edited my reply ( I think ! )
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,099
    You have the midline ecu module which is "midline" therefore will not support MFSW. You need to get an "F" module. Also you will definatley have to get a new airbag harness wire that supports MFSW controls. At the moment you just have a single harness lead for the airbag, the new harness is a split lead which plugs into the airbag, and into the steering wheel to allow use of buttons.
    After gathering the right modules and harness and fitting you then have the simple job of coding. :-)
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    May 2006
    WEST YORKSHIRE, UK
    12
    Thought it wouldn't have been as simple as plug and code. Bloody Audi..
    I appreciate everyones input and all the help, Thank You.
    Aug 2011
    244
    Can you retrofit DIS? Was it standard on any a3 variants?
