Sky InsuranceEM Tuning
    May 2011
    No sound from ConcertII
    My son has stuffed coins into my Concert II non bose (A3 Sportback 06) which have all been removed now by opening up the unit however there is no sound. Unit works ok, CD player, IPod connectivity, Radio, Phone all work just no sound so I suspect the amp chips at the back left are cooked. However before I get an exchange unit, is there anywhere else in the Audi audio wiring loom that could have been fried, or tripped/fused? I don't want to pay Audi service £50 for diagnostics on-top of £305 if I know the unit's goosed.
    warren_S3's Avatar
    Oct 2007
    6,132
    Have you checked all the fuses that relate to the audio system?
    Also may be worth disconnecting and reconnecting the cables just incase they didn't quite sit together properly.
    Failing that find someone with VCDS to see if the head unit is putting out an error code before you pay out.
    Can't imagine it's done it any good, but then that's the joy of kids!
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    26,762
    Quote Originally Posted by pulsejet View Post
    Diag would only maybe show it was disconnected or the shorted part isnt communicating in these instances, although if the wiring isnt connecting properly it will show this, but you do ideally need someone to look at it, whereabouts are you?
    As for replacement radio, give me a shout as we will probably be able to find it cheaper than £305, also tbh if looking at spending that much, maybe wise to put it towards a much better unit, still audi, rns-e which is far far better than the concert, PM me if interested
    Quote Originally Posted by warren_cox View Post
    Say that again
