Monster MotorsportVolks Autos
Results 1 to 7 of 7
    Pom
    Jan 2009
    13
    Where is Coolant Temperature Sensor? Help please!
    Could someone tell me where is the Coolant Temperature Sensor on A3 2.0 FSI please? a Photo would be ideal!
    Has anyone replace it recently? Do I need to disconnect anything else to get to it?
    Thank you in advance.
    Pom
    Jan 2009
    13
    Here I have attached some photos. Does it appear in any of these?
    Mcblow's Avatar
    Jun 2008
    82
    I need to know the same thing! cant see your pics for some reason mate
    Current cars...
    MK2 Golf 16v gti
    A3 8p 2.0fsi...
    Looking for 2002/3 Red S3 below 80k and £6k
    www.dubsuffolk.com
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    The coolant temperature sensor is located inside the coolant tank located to the left hand side of the engine. It has two small thin rods inside the tank. If you are having a coolant level warning on your dash but find your water is topped up, then it may be a case that the rods have built up rust and gone faulty. Cheap and easy repair, the coolant bottle does not come apart so its hard to get the rods so best bet is buy a whole new replacement from audi for about £20 and somemore coolant antifreeze water about £8. Three hoses to disconnect, but be careful not to spill the old water and also the coolant temperature connector to come off.
    Had to do this on mine a couple of months back.
    Audi wanted to charge about £200 to read fault codes, new bottle and labour, absolute joke!!
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by Dannykn9 View Post
    Danny - that's not the temperature sensor, that's the coolant level sensor ! Sorry mate !
    As far as I know there are two coolant temperature sensors, one on the engine block near the a/c compressor and the other one on the radiator.
    However, I have not replaced either so no doubt someone else will be along to help soon !
    Edit : just realised the car is an FSI and I was talking about a TDI ! Don't know where they are on the FSI but it's not in the coolant bottle !
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    HAHAHA My bad, silly me
    Pom
    Jan 2009
    13
    Here are the photos again. Sorry the first time doesn't seems to work.
    Please let me know if you can spot the Coolant temperature sensor in any of these. Thanks.
    Photo 3
    Photo 4
Tags for this Thread
