Results 1 to 14 of 14
Like Tree2Likes
  • 2 Post By audigex
Thread: a3 2.0 tdi 140 won't start
    Jun 2011
    Please help, i have a 2005 audi a3 2.0 tdi sport 140bhp. I got in it this mnorning and it wouldn't start, it took about 5 min to get it to fire. I put vagcom lite on, it has come up with glow plug circuit fault. Once it has started its fine for the rest of the day. I have booked it in to get it repaired, just looking for any ideas ? thanks mat6413
    May 2009
    West Yorkshire
    1,623
    Mine sounds similar, its a ******* to start in the morning also.
    Audi A3 2.0L TDI S-Line Sportback
    Jun 2011
    the car sounds like a shed in the mornings, it has justed been serviced. I hope its a relay or something, not a ecu fault,
    May 2009
    West Yorkshire
    1,623
    So does mine, it's very lumpy on tick over also.
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    Sounds like glow plug failure. Without glow plugs it will struggle to start unless its warm from driving earlier on.
    May 2009
    West Yorkshire
    1,623
    I thought glow plugs only work when the temperature was cold? A bit like a choke? Or am i totally wrong here?
    Jun 2010
    Coventry/Warwickshire
    2,074
    your totally wrong
    Fossie
    Rhubarb Triangle
    3,968
    Quote Originally Posted by Lingy. View Post
    your totally wrong
    So do you have any ideas to help ?
    May 2009
    West Yorkshire
    1,623
    your totally wrong
    Am i? Why's that then?
    tdi-man's Avatar
    Jul 2009
    1,609
    just put new glow plugs in mine £40.00 delivered
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm
    audigex's Avatar
    Jul 2011
    555
    Glow plugs do the same job as spark plugs, but in a different way. Basically a current is run through a wire in the plug until it "glows" hot enough, and that is then used to ignite the fuel.
    If your car is struggling to start, ie doing that "coughing" noise as it attempts to fire but doesn't quite catch, then try turning the key to ignition, waiting until the glow plug light goes out and turning the key off, then repeating a couple of times... sometimes the problem is that the plugs aren't being heated up enough to ignite the fuel: several attempts to heat the plugs can help (which is also why they usually fire after a while, but it's less effective due to the fuel cooling the plug down each time you try and fail to properly turn the engine on)
    Also effective when your battery is going flat or glow plugs are wearing out - not effective in petrol engines or if there's a problem with fuel/air going into the engine.
    AidenUK and tdi-man like this.
    Ibis White A3 Sportback Black Edition.
    2.0 TDI (170) Quattro
    Pics
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,122
    first thing i would do is get some new glow plugs in there mate they are cheap to replace and if they are failing then the car will be a right pain to start
    off the road boohoo anyone got a gearbox for me lol!!
    May 2009
    West Yorkshire
    1,623
    Quote Originally Posted by audigex View Post
    Ahhh i see, makes sense now! Thanks
    Lewis583's Avatar
    Mar 2010
    870
    Quote Originally Posted by FranA3 View Post
    Also while the top is off i'd check the injector loom for oil ingress
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
