JMB RetrofitsSky Insurance
    Jun 2011
    14
    NEED HELP QUICK!!HOW DO I STOP MY FAN FROM RUNNING?!!!
    I HAVE A 2.0 TDI 2003 AND THE FAN JUST KEEPS ON RUNNING WHEN THE CAR IS OFF AND I HAVE TO DISCONNECT THE BATTERY TO STOP IT DRAINING IT.ITS THE FAN ON THE LEFT AS I HAVE TWO.CAN SOMEONE PLEASE HELP BECAUSE ITS REALLY P****N ME OFF AND CANT GET IT LOOKED AT UNTIL NEXT WEEK!! CHEERS
    Mar 2011
    Wolverhampton
    125
    Is there an engine light on? Mind did this when the intake manifold flap failed and is common on diesels. Unplug it and fit a new fuse. To check if your fuse has blown open the fusebox in the engine bay and it is one of the fuses towards the front of the car. Hope this helps
    2006 A3 2.0 TDI Quattro S-Line l Team Heko Wind Deflectors l Celtic Tuning Remap l Rear De-Wiper l Pipercross Panel Filter l
    After a Passenger Xenon Headlight for A3 8P. No ballasts required. PM ME!!
    Apr 2010
    mine did that too had to replace the fan which was costly get it on vag com see if there are any faults..
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    I think there's something on this in the FAQ section.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    Yep it's the Fan Module ......I had the same problem 2 months ago....it's a common fault. It cost me £200 to replace all the fans.....
    Jun 2011
    14
    ok cheers guys
