Chris NottMonster Motorsport
Results 1 to 8 of 8
    Jul 2011
    Sampford Peverell
    131
    MY11 Sportback Rear Lights
    Hi guys, can anyone help me out as i am looking to upgrade my rear lights on my '06' SB and wondered if the MY11 lights are a straight swap or if they require any wiring?
    Also where is the best place to buy them other than eBay or the stealers?
    Any help greatly appreciated.
    May 2009
    West Yorkshire
    1,628
    Physically they are a straight swap as they are the same size etc but you will need adaptors (kulfatec ones) and also some one with VCDS to code them to the car.
    Audi A3 2.0L TDI S-Line Sportback
    May 2009
    West Yorkshire
    1,628
    There's chap on here called Nigel who can supply them for you.
    Jun 2010
    Coventry/Warwickshire
    2,074
    NHN username
    Jul 2011
    Sampford Peverell
    131
    Brilliant thanks for the info guys.. does anyone have a link for the harnesses?
    Foxy
    Apr 2010
    147
    Hi mate here is the link for the harnesses, get the lights from NHN as said above I got mine from him for about £233 iirc.
    KUFATEC GmbH & Co. KG - Facelift LED Rear Lights - Adapter - Audi A3 8PA Sportback 36507
    Foxy
    Apr 2010
    147
    P.S. ignore "not suitable for right hand drive" makes no difference on the sportback, have used these on mine and they work fine.
    Foxy
    Apr 2010
    147
    Just read the original post and regards wiring you will need to splice the loose wires on the harnesses together and then on to the grey/brown number plate wire on the boot lid under the internal panel, dont let this put you off its easy, done mine completely in 1 hour.
