MY11 Sportback Rear Lights
Dazza0685
Member
Sampford Peverell
Hi guys, can anyone help me out as i am looking to upgrade my rear lights on my '06' SB and wondered if the MY11 lights are a straight swap or if they require any wiring?
Also where is the best place to buy them other than eBay or the stealers?
Any help greatly appreciated.
Physically they are a straight swap as they are the same size etc but you will need adaptors (kulfatec ones) and also some one with VCDS to code them to the car.
There's chap on here called Nigel who can supply them for you.
P.S. ignore "not suitable for right hand drive" makes no difference on the sportback, have used these on mine and they work fine.
Just read the original post and regards wiring you will need to splice the loose wires on the harnesses together and then on to the grey/brown number plate wire on the boot lid under the internal panel, dont let this put you off its easy, done mine completely in 1 hour.
925
10
23
2K
9
945
26
2K
T8DPR
T
