Coming Home&Leaving Home+Needle Sweep on A3 BE 2009
Amirkhan2621
NULL
Hi Guys,
Ive got a 2009 BE Sportback A3.
Just wondering how to activate the coming home and leaving home function and the needle sweep which ive seen on some audis...
I dont have any software or hardware and just wondering can it be done through the DIS thats in the dash?
Or can i go to audi and request this to be done...i presume it will only take a maximum of half hour to do?
Amir Khan
Needle sweep is only on the S3 as far as I'm aware.
CH/LH to work properly requires wiring, light sensor & a button on headlight switch, there is however a hack but this means its on even during the day.
Should be a button below the day time running lights for the C/H lights ( a little rectangle one with a red light? )
Not so sure the above is true, just done the mod on my 09 BE and all works fine, one wire Block "E" pin 12 to earth - don't have the special button on headlight switch or light sensor and all works normally, only check Bit 7 in the Central Electrics.
