JMB RetrofitsAH Fabrications
    Jun 2011
    14
    what coolant do i use and how much?
    basically need to top up with coolant.i had a leak so put some k-seal in and now want to top back up with coolant so any help would be appreciated, thanks in advance
    27,028
    Car details helps when asking these questions mate.
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    651
    G12 plus plus
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    I just went to the Audi dealer and asked for a litre for my car. It was about £8 plus vat and was actually 1.5 litres.
    It's quite likely it's the same as other brands of coolant, but for the sake of a couple of quid I thought I'd get the proper stuff.
    As Adam says, G12 plus plus was written on my bottle.
    Looking at the expansion bottle on the car should tell you too. I've just noticed mine has G12 written on it.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    antmax7's Avatar
    sheffield
    300
    to start with you need to flush the excess k seal out of the cooling system
    then re fill with the correct coolant most cars produced after 2002 use red coolant but as you say audi will give you the correct stuff
    as i have said get the excess k seal out it will cause you major problems if not!
