AH FabricationsChris Nott
    tdi-man's Avatar
    Jul 2009
    1,589
    first start of the morning
    some times but not every time when starting first time in morning the first few seconds are are little lumpy then runs fine
    after that it's fine all day long first turn the key starts no probs.
    ANY IDEAS ?
    was thinking changing glow plugs ?
    no fault codes in vcds
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    warren_S3's Avatar
    Oct 2007
    6,201
    Hard to say with the specific maps / egr delete.
    Obvious guess is air / fuel mix, so as you say, if glow plugs are old will it be as a result of map over fuelling slightly at cold start and drenching the glow plugs? Dirt in the fuel system???? When was it last serviced?
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    tdi-man's Avatar
    Jul 2009
    1,589
    did it before the map glow plugs are 3 years old from gsf
    26,777
    Have you had any cold mornings to warrant plug usage, as hasnt exactly been freezing & they only get used at low temps.
    tdi-man's Avatar
    Jul 2009
    1,589
    no cold mornings here have ordered a set anyway and some fuel cleaner.
    26,777
    Assume fuel supply is fine, have you detach fuel lines 1st thing before morning start, stick pipe in a jug & get someone to turn over & see if the fuel is coming through pressured straight away or stumbles as such.
