Sky InsuranceAH Fabrications
    Jul 2011
    Trip Computer - Do I need to Replace whole cluster ?
    On my SE I dont have the Trip computer which is a little annoying.
    Am I right in thinking the only way to enable this would be to replace the whole unit to one that has the centre computer and also install the stalk as well? Are new units easy to re code with mileage etc?
    its a 04' if that makes any difference
    Khufu's Avatar
    West coast of Scotland
    5,693
    You do need to change the whole cluster to get the DIS. The mileage can be corrected by audi only if you buy a new one, they are able to recode the immobilizer (well, some of them - others are awkward buggers) but not alter the mileage on 2nd hand units. You would need a 3rd party to do this, I belive its about £120 to do the mileage.
    Jul 2011
    what a pain in the ass! does anyone know if there is anyway to even just tell/see the avg mpg?
    27,028
    Only if you fill tank, set to zero mileage & then you can manually calculate with mileage done, against the known tank capacity which iirc is 55 litres, when empty.
    Where abouts are you located, as I can get it coded in for you & probably supply the parts.
    Jul 2011
    thats waht i thought and im currently doing, oh well! will have to look at how much they are to replace and the stalk etc, im based in Bristol mate
    27,028
    Would depend on whether you want a white or red dis, PM me for further info.
