    Yaseen1991's Avatar
    Aug 2011
    102
    AUDI A3 SPORTBACK FACELIFT REAR LIGHT TROUBLE!
    Hello, I am a newbie and this is my first post! So please excuse me if this has been covered before
    Ive got an a3 sportback on a 07, and i recently bought the facelift rear lights to stick on, the one's with the inner tubes which light up.
    Ive come to put them on and encouterd problems straight away, the original plugs are 4 pin and the 1s are 6pin on the outer lights, a bit of diy wiring and there on.
    The inner lights are a 3 to 4pin, but im missing the Plugs! Thts problem 1, i need a set of 4 pin plugs to stick into the new inner lights
    Now the main problem, the tubes are not working as they should, the lights are all stayin on! It all looks a but too much
    I was wondering if Any1 sells a plug and play adaptor for the light plugs or anything like that so i can just get the lighs working??
    Thanks for any help in advance
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    If you use the Search facility there are loads of pages explaining how to do this. Here are a few:
    Sportback Rear LED's
    Coding For A3 Sportback Led Rear Lights Retrofit
    Sportback 09 rear lights
    Sportback rear lights
    I
    n brief, you'll either need to buy the plugs from the dealer and make your own, which can be a pain if you don't know what you're doing, or buy the Kufatec adaptor's. You'll then need to get them coded by someone with VCDS otherwise they won't work properly, as you've discovered.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    Yaseen1991's Avatar
    Aug 2011
    102
    Cheers mate! Ne idea wer i can get the Kufatec adaptors from? Thanks
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,788
    Quote Originally Posted by Yaseen1991 View Post
    google? KUFATEC GmbH & Co. KG - A3 - 8P / 8PA / Cabrio
    Dark Vader Half sibling - MyThread
