Volks AutosAH Fabrications
Results 1 to 13 of 13
    Jul 2011
    65
    Convert LHD S3 Xenon Headlights for UK compatibility
    Hi!
    Im doing a facelift S3 conversion on my 2006 a3 and ive been offered a set of S3 LED xenon headlights from Germany I'm just wondering if these can be made compatible for use on UK roads. From my understanding the beam pattern will be way off.
    I hope someone can shed some light onto this.
    If it is possible then i may be able to get a great bargain
    Thanks in advance!
    Chappy's Avatar
    Call me Dan :)
    Sep 2010
    Grimsby, UK
    449
    Been looking at them on German ebay aswell, a lot cheaper
    I'd also like an answer to this please!
    AudiA3 2.0TDI S-Line
    Phantom Black | Leather Seats | Heated Seats | Black Optics | AMI | Badges Deletion | Rear Sunblind | Armrest | Darkened Glass | S3 Chrome Grill | H+R 10mm Spacers up Front | H+R 13mm Spacer at Rear | Mtec Cosmos Blue Bulbs | Cared for Paint Work |
    slade777's Avatar
    Sep 2010
    763
    I may be wrong but I know using VCDS you can change the beam pattern to continental driving. Possibly this is all thats needed!?!?
    Current:
    A3 Black Edition 2.0 TDI 140
    Apr 2010
    149
    u can change them however it doesnt change the beam pattern, it only lowers it, so i guess you could be ok? id prbly go for it
    Chappy's Avatar
    Call me Dan :)
    Sep 2010
    Grimsby, UK
    449
    Would be nice if it could be done, they're a lot cheaper from Ze Germans
    Chappy's Avatar
    Call me Dan :)
    Sep 2010
    Grimsby, UK
    449
    Can anyone with xenons as standard have a look in their manual and see what it says about driving abroad?
    An old BMW my mum had, had a screw you turned and it did something to the beam, I was only about 12 years old at the time though
    VAG COM virgin
    Nov 2007
    Devon
    Hi I have xenons as standard on RHD A5 . The manual says can be adjusted via MMI however the option is greyed out. They are easily changed by VAGCOM however CHange channel 10 from 0 to 1 and vice versa. Unfortunatley a message comes up un DIS every time the car is started warning light converter is active. Could be annoying if using car in UK all the time
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    Quote Originally Posted by aa_autos View Post
    Hi!
    Thanks in advance!
    So the answer to this important question is... NO!
    LHD lights will not work unfortunately, this has been covered before and explained in detail... they would be great if you are going to take the car abroad and drive around out there but to have them here in the UK will be a massive problem. they cannot be converted either...
    sorry
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    also for anyone wanting to read up more on this topic:
    LHD Bi-Xenon
    Audi Bi Xenon Retrofit
    Retro fitting xenons question
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Quote Originally Posted by Chappy View Post
    i can check on monday when i pick her up
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade, fully machine corrected!
    Aug 2011
    242
    Typically on rhd lights, the adjustment cuts off the high part of the beam that illuminates further ahead on the pavement. This is obviously a mirror image of the lhd beam pattern.
    When you flick the switch it makes it all flat. It is therefore fine to drive on the wrong side with these but it doesn't light up as much in your outer vision.
    The thing is, on previous cars I've tinkered with the lights of, lhd lights don't tend to have the facility to flatten the beam because driving in the uk is a less likely situation whereas for uk cats there's a much bigger option of countries who drive on thd right to visit.
    If they are switchable then it will be acceptable but will give you a smaller illuminated area.
    In short, not worth the saving.
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    chappy how much where your spacers i may get some
    26,720
    As above, not a chance, dont waste your money.
