Sky InsuranceVolks Autos
Results 1 to 11 of 11
    May 2011
    60
    Heater blows cold
    Hi guys. turned the temp up on my climate control tonight and it only blows cold/warm, even on 25 deg its not hot.
    Air con is ice cold, but something certainly not right with the heat side of things.
    Any ideas??
    audigex's Avatar
    Jul 2011
    555
    How's your coolant level? Was your engine up to temperature?
    May 2011
    60
    Quote Originally Posted by audigex View Post
    Yes. Been driving around a hour, and coolant fine
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,767
    Check your fuses
    Thermostat??
    quattro81's Avatar
    All the gear.. No idea
    Feb 2011
    Kent
    982
    If you have vcds it's worth a plug in... Could be the motorised flap that switches from hot to cold.. Had this recently in mrs golf...
    Red is the colour..
    salad.dodger's Avatar
    May 2011
    Berkshire
    68
    mine did this, thermostat getting stuck but my temp gauge went up.
    Chappy's Avatar
    Call me Dan :)
    Sep 2010
    Grimsby, UK
    449
    I had the same problem last night, although it did eventually start blowing warm air after having it set on HI for a while, I shall monitor it and get it back to Audi if needed.
    AudiA3 2.0TDI S-Line
    Phantom Black | Leather Seats | Heated Seats | Black Optics | AMI | Badges Deletion | Rear Sunblind | Armrest | Darkened Glass | S3 Chrome Grill | H+R 10mm Spacers up Front | H+R 13mm Spacer at Rear | Mtec Cosmos Blue Bulbs | Cared for Paint Work |
    May 2011
    60
    Thanks guys. Temp gauge is reading normal, think i'll start with the thermostat then move on from there if no joy
    shady-ninja's Avatar
    843
    if you change the thermostat and the problem persists the it might br the HEATER EXCHANGE MATRIX.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,850
    Quote Originally Posted by mark7 View Post
    Sound like a thermostat to me...
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Khufu's Avatar
    West coast of Scotland
    5,693
    even if its the thermostat jamming open it would eventually heat up. Is it a diesel? mileage? My worst fears concern would be cylinder head gasket being away causing back pressure that stops the circulation of coolant but as gauge is reading fine it could be blocked matrix (feel the pipes in & out of the bulkhead) or a fault with the control panel/flaps as suggested above.
