Hi all, I'm new to the forum and have so far had my 2010 Sportback for less than a week but I'm absolutely loving it
But I cant live without my ipod connection and need to get one installed.
i've opted for the connects2 adapter rather than the dension (i'm not fussed about the display), but before i install I wanted to take a look and see if anything else here had any tips.
sorry if this has already been asked, but i havent been able to find this question anywhere...
at the moment, i've got the factory fitted bluetooth (low Prep) and double din concert stereo, and i'm worried i could lose this and the acoustic parking sensors when playing around with installing the cable in the back. will it be ok to pull the stereo out the cage, install the ipod cable without the ignition in, and then put it back in place, or will it require disconnecting the other wires, battery etc?
i'm worried i'll have to put in all sorts of codes etc to get it back up and running, and i wouldnt have a clue where to start on that.
and, does anyone know if the glove box will have to be drilled to run a cable in, or are there any hidden panels inside i might be able to slot the cable through? i really dont like the idea of drilling holes just yet.
thanks for any advice all, and if i see any A3's in the romford area, i'll give you a little wave
adam.
adam.
