Sky InsuranceEM Tuning
    tdi-man's Avatar
    Jul 2009
    1,587
    CAM BELT KIT AND WATER PUMP
    MY WATER PUMP AS TINY LEAK so getting it done soon which is the best to get genuine or none genuine
    also shoukld i get pump with plastic fins or metal ?
    same as the cam belt kit does it matter if genuine or none genuine ?
    thanks
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    trev m's Avatar
    35
    my a3 2006 was done by AMD Technik a sponsor of the forum
    belts and metal water pump inc antifreeze
    I think the parts come from GSF | Cheap Discount Car Parts | Euro German Japanese | VW BMW Audi Ford Peugeot
    tdi-man's Avatar
    Jul 2009
    1,587
    Yes used them before fir the bits but have a small leak running
    Down the back of the block so may get a genuine
    Pump
    TimG's Avatar
    Feb 2004
    South Coast
    932
    General consensus is replace the plastic impeller pump with a metal one to avoid future breakages.
    Most indi's advise that replica parts are made to OEM quality anyway so I wouldnt worry too much about OEM parts. I never have and touch wood, never had am issue.
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    438
    Not sure if it's the case now, but I remember when I changed the water pump in my mk4 Golf, VW only supplied pumps with plastic fins & GSF supplied pumps with metal or plastic fins.
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
