JMB RetrofitsEM Tuning
    munchkincoupe's Avatar
    Aug 2010
    971
    Brake fluid quantity?!?
    8P1 is due a service and going to get upgraded brake calipers fitted front and rear then too. What quantity of brake fluid would be needed to do this job please?
    warren_S5's Avatar
    Oct 2007
    7,164
    I think from memory it's about 1.5 litres, so get 2 litres to be safe (need to allow for it to run right through.
    Are you doing it yourself? If so you need VAGCOM to flush the ABS pump as well as a pressure bleeder.
    Audi S5 3.0V6T Coupe Black Edition
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    All models of A3 8P1 are 1 litre capacity (according to Autodata). 2 litres will give you enough to give it a good flush through.
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
