Badger5Volks Autos
Results 1 to 9 of 9
    Jul 2011
    7
    Exclamation smell petrol in oil!!!
    HI I HAVE AN AUDI A3 2.0 T FSi S line Special Edition, 3 Doors, Manual, Hatchback, Petrol, 2006. ON CHECKING DIP STICK FOUND A STRONG SMELL OF PETROL COMING FROM OIL. ANY IDEAS OF WHAT THIS COULD BE? THANKS, ALLY
    warren_S5's Avatar
    Oct 2007
    7,164
    Cam follower wear, or fuel pump seals. Mileage?
    Audi S5 3.0V6T Coupe Black Edition
    Jul 2011
    7
    97K MILES DO YOU THINK IT COULD BE PISTON RINGS? WOULD THERE BE ANY OTHER SIGNS? THANKS
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Dribbling injector, worn rings. Does it blow like a leaf blower out the oil filler cap ?
    Jul 2011
    7
    just a bit of steam
    Jul 2011
    7
    how much do you think any of these would be to fix?
    afcjay's Avatar
    Aug 2008
    426
    could just be a blocked breather
    3dr Dolphin Grey Audi A3 2.0 TDI S-Line
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    This happened to me, and was going on unnoticed for a while and lead to my turbo blowing :-(..at first it was very subtle so easily missed- no smell etc.
    Mine was caused by worn seals both within the HPFP and within one of the injectors. Got a low mileage set put in my Stattler which cured the problem. Best not to drive the car too much till its sorted ,as your oil's not going to be doing its job properly.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Jul 2011
    7
    are you based in glasgow any garages you reccomend how much to rectify? thanks
