EM TuningChris Nott
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,767
    Parts Required for Cam/Timing Belt Change - S3 2007
    Lads
    Getting my belt done and sourcing my own parts.
    So I need:
    Water pump (£44 from ECP)
    Timing Belt (£35 from ECP)
    Coolant
    Tensioners Idlers and Dampners?? (£93 from ECP, £27 from buypartsby??)
    Is this correct? Anything else worth doing?
    This is the link to the over running alternator pulley from buypartsby. There are two stated for my car, which one?
    Belt Tensioner Pulley | Audi S3 2.0000 2007 | BuyPartsBy
    Andrew
    Boydie's Avatar
    Boycie
    Dec 2006
    4,767
    Anyone?
    Fossie
    Rhubarb Triangle
    3,961
    Talk to Dave at Stoke Audi
    For such an important element of the engine I suggest you go for OEM parts only and you should replace all parts 'in contact' with the belt.
    He will tell you what parts are required and give you a price which will include a discount for ASN members.
    Flat Out
    Apr 2007
    Essex
    144
    Does it really matter? they are the same part no.
    Boydie's Avatar
    Boycie
    Dec 2006
    4,767
    I live in Northern Ireland and have an account with TPS so will be using them more than likely for the belt kit.
