Volks AutosJMB Retrofits
Results 1 to 9 of 9
    3DTDi's Avatar
    Jun 2011
    Bristol/Gloucestershire
    239
    DPF Light Question
    Hi guys, my DFP light has just come on which I know isn't great news, the car is going to Audi next week for a service anyway so will get it done then but does anyone know roughly how much they cost when changed by Audi? Also will I see any performance difference once changed or will the car drive smoother?
    Any advice or experiences welcome
    A3 2.0TDi 170 S Line Brilliant Black
    Plans: FBMFSW, RNSE MkII, S3 Diffuser and Skirts, OEM Bi-Xenon
    bigman75's Avatar
    Jun 2011
    Wolverhampton, West Mids
    35
    A DPF light doesn't necessarily mean it needs replacing. You should be able to clear it by taking the car out for a 'spirited' drive. Try 4th - 5th gear 2-2.5 k RPM for about 15 minutes. Motorway or decent A road is the preferred option. Whack down the M32 mate!
    Your handbook will explain it or just google it. If your light is persistent after trying the above then it may indicate a further fault which your dealership should be able to diagnose.
    A3 S-LINE Black Edition, Quattro 2.0 TDi 170, Volcano Red with lots of tasty extras...........yum yum!
    Bom Shanka! May the seed of your loin be fruitful in the belly of your woman!
    Jul 2010
    Merthyr Tydfil, United Kingdom
    874
    It could be a faulty sensor. Get it scanned with VCDS. Check out the users location map to locate someone near you who will scan the car for beer tokens rather than have Audi relieve you of lots of your hard earned
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    650
    Unless it says DPF fault drive to dealers then it should be fine.
    I used to take mines a blast in 4th gear along the motorway and it would clear in a few minutes.
    You can tell if the car needs a regen as it will idle higher than normal.
    3DTDi's Avatar
    Jun 2011
    239
    Quote Originally Posted by Adam. View Post
    Thanks for the replies chaps. The car has been idling slightly higher that usual so you think a blast will sort it out?
    v1raj's Avatar
    Apr 2009
    279
    Get the dpf deleted and then map it
    2006 Audi A3 (8P)
    Spec - 2.0 TDI l DSG l Sprint Blue l Leather Interior l 18" RS6's | H&Rs | S3 Front | 6k Bi-Xenons | EMTuning DPF Delete Package
    Plans - BBS
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    650
    Quote Originally Posted by 3DTDi View Post
    Yup it just needs to regen. You need to take it on the motorway and keep the revs above 2k untill the light clears. I popped it on cruise at about 3k and it would always clear in a few minutes.
    If you don't let it regen then you will get a message saying it needs to visit the dealers and they will need to force a regen.
    3DTDi's Avatar
    Jun 2011
    239
    All done thanks chaps! took 4 mins of about 80mph in 5th and the light just went back to radio station. Many thanks for your replies
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    650
    Glad to hear it!
