Sky InsuranceBadger5
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,465
    need a bit of help
    a3 1.6 53 plate
    got this with vcds as did the aa and rac
    car wont start i cleared code turned it over and code came back
    had the sensor changed earlier still no start cleared code still no start code came back anything else i could try
    it was mentioned the crank sensor could be faulty and can cause this code any truth in that ?
    16725 - Camshaft Position Sensor (G40): Implausible Signal
    P0341 - 008 - Implausible Signal - Intermittent
    Freeze Frame:
    RPM: 4832 /min
    Mass Air / Rev.: 463.3 mg/str
    Bin. Bits: 00001000
    Temperature: 82.5°C
    RPM: 288 /min
    Mass Air / Rev.: 267.1 mg/str
    Bin. Bits: 00000010
    Temperature: 82.5°C
    Fossie
    Rhubarb Triangle
    3,969
    This is what Rosstech have to say :-
    16725/P0341/000833 - Ross-Tech Wiki
    bez101's Avatar
    Jul 2008
    8,465
    yeah i always use that for codes
    new g40
    timeing spot on
    wireing ok
