Volks AutosEM Tuning
Thread: nhn in box full
    Apr 2011
    197
    nhn in box full
    hi mate your inbox is full so here is the info you need
    Signal Tyre pressure gauge
    TPM
    The tyre pressure monitor is a software module in the ESP/ABS control unit to detect slow tyre pressure losses on individual wheels. The system detects pressure losses of more than approximately 30% of the starting pressure.
    A recalibration is required after every pressure change, after every tyre change (including swapping from front to rear) and after any work has been performed on the running gear.
    1. Basic setting/restore delivery condition
    After every system reset the tyre pressure monitor must be started up for at least 2 seconds by simultaneously pressing the tyre pressure monitor and TCS/ESP buttons. After an initial calibration no further calibration is necessary.
    2. Calibration (save tyre pressures)
    Press and hold the TPM button at ignition on for > 2 seconds
    TPM lamp remains lit as long as the button is held down. A successful calibration is acknowledged by an acoustic tone. A successful calibration can be checked indirectly by way of measured value block 17 by comparing the kilometre reading in measured value block 17 with the current kilometre reading on the speedometer (to an accuracy of 10 KM).
    3. Diagnostic aids
    MVB 16 kilometre reading and last pressure warning
    MVB 17 Kilometre reading at last initialisation
    MVB 18 TPM button
    4. System error- fault memory ABS/ESP
    A system error is indicated by the TPM remaining steadily lit and by an entry in the fault memory of the ABS/ESP control unit. (fault 2214 Tyre pressure warning).
    The control unit must be reset to its delivery condition
    Switch to vehicle self-diagnosis
    -Select function 03 - Brake electronics
    -Select function 04 - Basic setting
    -Select channel 042 - press the Activate button
    Then initial calibration must be performed - see item 1
    5. Adapt tyre size
    -Select function 10 - Adaption
    -Select channel 01
    Enter the number 0 and tyre size 15 inches
    Enter the number 1 and tyre size 16 inches or larger
    let me know if it sorts it out
    27,096
    Sorted inbox, replied with solution found.
    Butttttt, all that info above is very very much appreciated mate.
    Thanks again.
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,923
    lol, you busy PMing again Nige !!!
    27,096
    Not so much girl, keep missing you on msn though huh, oh sugar msn isnt even open, oops lol
    Sarah's A3's Avatar
    5,923
    lol, we have had such bad internet connections but all sorted now so will log on
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Nigel's box is always full
