AH FabricationsChris Nott
    Jul 2011
    VAG Commander 2004 8P 1.6 A3 instrument cluster help!
    Hi all,
    I connected up VAG commander and a connected via CAN BUS 2.0 to my ECU and without meaning to change anything (although I did press coding tab on the left which said coding unit successful), Somehow I have changed the odometer from miles to kilometres and the cars instrument panel is behaving as if it were a foreign car.
    For example, when left door is open it shows that the right door is open.
    On switch of ignition i'm also presented with a warning telling me to apply brake when stationary when selecting gear.
    Does anyone know how I can get this back to normal!?
    I did manage to read the eeprom, can this be edited somehow to correct the country settings?
    Jul 2011
    eeprom.bin - eeprom.bin here
    Jul 2011
    Hello,
    Don't play with eeprom.bin - because you didnt damaged the BIN FILE. You "only" screw up the coding. I had the same problem with VAG K+CAN commander. The coding was wrongly given. When you open the software you have to put the coding in the HEC ( value) windows instead of DEC(Valeu).
    Coding of the dash you will find here:
    Audi Portal: ECU Diagnostic . Audi A3 8P (2003- ) . Instrument Cluster J285
    If you need more info type on witanski.dariusz@interia.pl I will try to help you.
    RGDS
    Dariusz
    Jul 2011
    hi again,
    I had the same situation - when you press "Coding" on the menu on left - the module was code with defautl number - in this case it was 1 or 0.
    Use Hec(Value) and link to coding and everything would be ok
    RGDS
    Dariusz
    Mar 2012
    Quote Originally Posted by witanus View Post
    hi again,
    RGDS
    Dariusz
    I have dne the exact same thing on a Seat Leon 06 plate. Do you know where I might be able to find the codes to reset it?
