Monster MotorsportBadger5
    JNP
    JNP's Avatar
    Jan 2011
    Basingstoke
    102
    Quick question on tyres
    I recently bought some genuine 18" ET43 rs4 style alloys that have tyres on them.
    The tyres are in pretty good nick so ideally i want to keep them on there but the only issue i can see with them is that they are 235/40/18's?
    I am driving an 04 a3 sport on standard sport springs, will having 235's be an issue??
    S3 8L AMK 51' - V3 Badger TIP - Jetex Cone w/ Heatshield - Forge FMDV008 - DS2500 Front Pads - 312/256 Discs - HR Sportkit
    JNP
    JNP's Avatar
    Jan 2011
    Basingstoke
    102
    Just an update on this, I fitted the wheels as above and the stance looks great. The only issue I have is if the car is heavily laden and I go over a relatively severe bump or dip in the road I get a slight rubbing noise from the rear drivers side arch??
    Do you think if I had 225 tyres on there this would stop happening or is this something you always experience when you have a wider offset like ET43?
    Thanks guys
    warren_S5's Avatar
    Oct 2007
    7,135
    235/40/18's are likely to make your speedo reading slightly out (don't know which way). 225's should stop the rubbing.
    I'm running 235/35/19 with Et45 and I get very slight rubbing with all seats taken.
    Audi S5 3.0V6T Coupe Black Edition
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    If the diameter of the wheel and tyre is increased (which it would be if you fitted tyres that are wider, but have the same profile) then you would be travelling faster than your speedo shows. Only very fractionally though, as the 40 profile on a 235 will only be slightly bigger than the 40 profile on a 225 tyre.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    JNP
    JNP's Avatar
    Jan 2011
    Basingstoke
    102
    Thanks guys, I guess I will wait till the tread is low and replace them to some 225's then.
    The Engineer's Avatar
    Apr 2011
    Mid / Northwest
    336
    I have 235 on the rear and 225 on the front,
    i am on standard sport springs too with no rubbing.
    Mine looks quite high to be honest and would like it lowered soon.
    considering getting S-line springs.
