EM TuningMonster Motorsport
    May 2010
    24
    Engine Overheating during idle.
    Hi,
    I have Audi A3 2.0 TDI (140) 05 plate.
    I was in London other day and got stuck in horrerous traffic barely 100 yards per 5 min! I even had gearbox in netural position, handbrake on when not moving and its suddenly went to 100 degree even its had a proper coolant liquid in and on maxmium level. Mind you that day was about 30 degree outside!
    When its got 100 degree and I put full heat on and its went back the normal temperature (middle. 50 degree if I remember correctly) then switch heat off its did happened again but when I am moving such as got out of London and its was on right temperature (middle) and never got overheating again.
    What fault could be for this? I am just concered as I don't like damaging my engine.
    Audi A3 2.0 TDI Sport 3dr Black. The Murdered Out Project!
    So much to do so short time! List to do - Neverstop list!
    Running on Standard at the moment. Wont be so standard near date! Watch this space!
    symun's Avatar
    Jun 2011
    Swansea
    147
    i thought it was normal for it to be around 90. if not then your fan may have packed up. if its just been renewed then it probably wasn't bled properly.
