Chris NottSky Insurance
Results 1 to 9 of 9
    Jun 2009
    173
    Water/coolant temperature problem
    My 2008 S3 water temp seems to drop every now and then after it has hit 90 degrees. Even after a long 1 hour drive on the motorway the temperatue just slightly drops and then slowly goes back up. I've put it on a VCDS and there aren't any sensor faults. Any ideas? Thanks
    Sportback owner
    Apr 2007
    France
    492
    Bash, it sounds like a sticking thermostat. This is a mechanical device, so would not show up on VCDS. I don't think that the thermostat element is too hard to get at, and probably does not cost much to replace. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    As above, thermostat for definate... Has the same on my old Golf MK4
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Jun 2009
    173
    Thanks for the replies, will have a look!
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    After an hours drive on the motorway it is quite reasonable for the thermo to shut and reopen. All it is doing is maintaining the temp at 90. Sounds to me like its doing its job.
    If however the temp was not being adjusted back to 90 then i would see that there was a problem
    Audi Heaven
    Somerset
    1,861
    Quote Originally Posted by paddy View Post
    My temp guage never moves from 90 though, where as when the thermostat went on my Golf it would drop back etc.... Does yours move then Paddy??
    Scott
    Sportback owner
    Apr 2007
    France
    492
    The thermostat will regulate the temperature very accurately. No more than a whisker of movement on the needle. If you are seeing a difference in temperature, it's the thermostat which is not providing the usual fine control of temperature that we normally expect. Suggest you replace the thermostat and see the difference. Not expensive, but of course not a major problem also.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    To be honest, well yes it does but only by the thickness of the needle. In traffic it will drop by more when the fan cuts in. the V6 has 2 rads and 3 fans so maybe its a bit more sensitive ?
    Jun 2009
    173
    This is my fourth audi in recent times and it's the first time I've seen it happen. When it moves more than the needle width it's a problem I think.
