It's called a Sportback, and the only spoiler was from the S-Line and/or S3. I think they are the same for 3 or 5 door so should fit. Some spoiler require the high level brake light to be repositioned though...
Yep, the 3 door and Sportbacks are definitely different.
There is also a difference between the S3/S-Line spoiler and the Votex one. The S3/S-Line comes with a new brake light, whereas the Votex has a cut out so you can see the original 3rd brake light.
I learn something new everyday. Never had to fit one as mine came with it, but I knew the brake light was a factor somewhere, but I didn't know the 3 and 5 door spoilers were different....
