EM TuningChris Nott
Results 1 to 20 of 20
    afcjay's Avatar
    Aug 2008
    426
    Help changing side light bulbs w5w
    Replaced my headlight bulbs for some whiter looking Philips bulbs which was easy enough to do but now im looking to replace the side light bulbs also (w5w) but cant get my hand into the unit
    Can anyone tell me what the best way to go about changing them is and do they just pull out or twist/pull out?
    3dr Dolphin Grey Audi A3 2.0 TDI S-Line
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,149
    They just pull out.
    Best way to do it is grab the wires and pull out. DO NOT yank the wires, just pull softly until the slack is taken up and then firmly and evenly pull the bulbs out.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    Quote Originally Posted by aythree View Post
    They just pull out.
    what he said , they just pull out matey can be a bit of a pain to get back in but if you look through the front of the light you should be able to see the bulb when you are trying to line it up so it will go back into the hole
    off the road boohoo anyone got a gearbox for me lol!!
    afcjay's Avatar
    Aug 2008
    426
    thanks people ill get on them tomorrow
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    once yo have done them once you will do them so easy the next time they dont take long at all to do 5 mins tops
    Fossie
    Rhubarb Triangle
    3,961
    When putting them back in switch the lights on and look in from the front. It will help you align the bulbs with the hole.
    afcjay's Avatar
    Aug 2008
    426
    thanks for the replys/advice
    Bailey's Avatar
    Jun 2009
    Alton, Staffordshire
    240
    Sorry to revive an old thread but I had a look at changing mine tonight and just wondered which way is easiest to go in? Is it through the main headlight compartment or the dipped headlight compartment?
    Fossie
    Rhubarb Triangle
    3,961
    Main beam (inner) light. The two compartments are totally separate assuming you have halogen lights.
    Bailey's Avatar
    Jun 2009
    240
    Ok thanks, I will give this a shot tomorrow night after work when I have got some light. Is it an "ok" job to do? Is there any special trick to doing it. From what I looked at in my car and read earlier it looked a pain in the arse
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,163
    You can always use a long this screwdriver flat head, as long as it reaches to where the sidelight is, just pry it out. It pops out very easily that way.
    Fossie
    Rhubarb Triangle
    3,961
    Just use your fingers to grasp the wires firmly and pull slowly backwards. Do not 'yank' the cables - firm pulling will pop them out easily.
    When replacing I find it easier if you actually turn the light on and look through the front glass to line the bulb holder up with the hole in the reflector.
    Bailey's Avatar
    Jun 2009
    240
    Thank you for the tips, I will try this perhaps on my lunch break or tonight after work
    May 2012
    39
    You could also try using an old coat hanger (this is what I did although I had to bend the hanger slightly to make things easier).
    Bailey's Avatar
    Jun 2009
    240
    Just tried doing this on lunch break at work and I couldnt do it. Tried with long nose pliers and still couldnt get the blighter out.
    I didnt pull too hard in case of breaking it. I can get at the unit but when I pull slowly it doesnt budge. I also tried with my hands too
    Bailey
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,071
    Quote Originally Posted by Bailey View Post
    Bailey
    Weird they didn't come out that easy as although awkward mine were actually quite loose both getting them out and once I had put them back in.. Fiddly but shouldn't have to use pliers.. Stupid design though in my opinion
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Mar 2012
    Cumbria
    91
    Bailey
    To be fair the wires are fairly secure in the holder, I replaced both of mine yesterday. Just give them a twist first then they should come out a bit easier, I had to give it a little tug by the wire as they were stuck solid. Probably not the best practice but it got them out.
    Also on a side note when I pushed my light back in it went with some force and bulb actually came out of the holder and ended up on the inside of the light unit! Luckily the bulbs were metal bodied LEDs and I had an extendable magnet handy!
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,071
    Quote Originally Posted by quinnii View Post
    You never know when you might need an extendable magnet I always keep one on my person ;-)
    Seriously though lucky as I can't imagine getting it out with that would be easy!
    Fossie
    Rhubarb Triangle
    3,961
    Bailey
    Be firm with them and gently rock the wires from side to side first. They will come out, you just need confidence !
    You should not need to use pliers
    Bailey's Avatar
    Jun 2009
    240
    In the end my mate (mechanic) managed to do them easily for me, it was a bit fiddley and even he said they are a stupid design
    Thanks for all the help guys
    Bailey
