Volks AutosAH Fabrications
    Feb 2011
    south west
    10
    A3 2.0 tfsi dsg solid brake pedal
    Hello peps
    After some advice, every morning I put me foot on the brake pedal & it's solid, as if I'd been pressing the pedal with the ignition off. Brakes seem to be fine after the car has started, but the same every morning.
    I was wondering do I possibly have a calliper sticking? How would I go about finding out which one? If stuffed then could be time for some upgraded brakes ...
    Probably unrelated - but I had the cambelt & dsg service done recently??
    Any help would be most appreciated
    I tried plugging into VCDS - but I've gone & bought the wrong lead - dooh....
    Lewis583's Avatar
    Mar 2010
    829
    Do you mean "Every morning" before you started the car? If so, the thats normal as there isn't any servo assistance due to no vacuum.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Khufu's Avatar
    West coast of Scotland
    5,693
    Without the engine running the brakes should feel solid/wooden. The minute you start the engine the vaccum should aid the brakes so if solid with the engine runinng 1st thing then it could be you have a small leak in a vaccum pipe. It could have been disturbed when doing timming belt, im not sure of the system on a diesel engine.
    Feb 2011
    south west
    10
    Thanks-guys,
    Lewis it really is solid - can barely press it.
    Khufu - it's the petrol 2.0 tfsi - do you happen to know where this vacum pipe is? When I get some light I'll have a hunt under the hood.
    Lewis583's Avatar
    Mar 2010
    829
    As long as the brake pedal isn't hard when the engine is running all is good mate.
    When the engine is running it creates a vacuum which is used by the brake servo to assist braking effort, obviously engine not running = no vacuum = solid pedal.
    Full VCDS
    Khufu's Avatar
    5,693
    Quote Originally Posted by spikeydoo View Post
    Thanks-guys,
    mmm, i dunno why I thought I read it was a TDi LOL. If you look at the master cylinder/servo there should be a pipe that goes from that to the intake side of things.
    On mine, its the black pipe coming from the black servo.
