JMB RetrofitsAH Fabrications
Results 1 to 7 of 7
    Jul 2011
    13
    Audi Symphony 2 cd 1 error 3
    Hi lads, I had 6 discs in my Symphony 2 player, and it decided to get jammed up, thus having error 3.
    I do not have the code for the unit :/
    I have taken out the unit, and managed to get all the cd's out. Now when i switch on the player and press cd it says none in slot which I think good, but then I press to load a cd it says waiting for cd 1, then comes up with cd 1 error 3. The radio still works, but I still get the error even with no cd's in the unit.
    I have tried pulling the fuse and taking all the cables out, and the problem still persists ?
    Any ideas would be apreciated please !!!!
    27,099
    Welcome btw.
    Have a read here & if you still have no joy, I have a concert 2+ available.
    CD Error 3 on Symphony 2 - Help!! - Audi Forums
    Jul 2011
    13
    thanks mate, i will check and may come back !!
    How much for the concert 2, is it the same as he one I currently have ?
    27,099
    Same as this:
    Jul 2011
    13
    27,099
    Have you tried loading/unloading a disc to see if anything is not lining up?
    Jul 2011
    13
    I have, but it wont accept, nor eject. However it seems to be slot 1. I have managed to press load, then select disk 2 and it accepts disk 2 and plays fine and ejects. But the only way to get the player to accept cds is to switch it on, press cd button and push the caddy down so it clicks. Then press load then number , then it accepts the cd. Something seriously wrong with this unit - and most irritating
