AH FabricationsChris Nott
    Oct 2008
    14
    Smile Bluetooth Module
    Hi Been looking at various previous threads on bluetooth modules and just have a question.
    I currently have a 2005 A3 sportback with factory GSM and multi function steering wheel, I retrofitted RNS-E some years ago and have never been able to get the phone directory to work on the RNS-E or my iphone 3GS to sync with my GSM it pairs ok and can use the phone through the system to answer calls etc, but I can not scroll through my contacts when I press the mode button on the steering wheel it just says no entires unlike my old nokia which enabled me to scroll through the address book.
    My question is I have been reading about that I probably have a old bluetooth module looking at the list 8P0 862 335 which is for a 2004 MY A3 europe. If I replaced it with a later version say 8P0 862 335 S which is a 2009.5 MY would this solve my problems.
    Regards
    hambo0
    Adam.'s Avatar
    Meow.
    Mar 2011
    Glasgow
    634
    Don't you need to code the RNS-E in so that it will connect?
    26,747
    Did you code it in properly, as you have to enable certain features.
    Oct 2008
    14
    Hi sorry for the late reply been away.
    I did try coding it sometime ago, I did my research on here and borrowed a cable along with the ross tech software, but I had trouble changing the values, To be honest Im a complete novice using the software.
    What features do I need to enable?
