Chris NottEM Tuning
    Apr 2011
    Doncaster
    68
    Coming home and Leaving home lights - VCDS trouble
    I'm trying to do the CH and LH light mod like on this link to my 2007 A3 Link
    I've done all of the wiring and plugged in VCDS but if I go into the long coding helper and onto Byte 0 I only have Bit 3 and Bit 4 available as check boxes. Not the 5 and 7 as suggested in the guide.
    Is this function not available on my model or is VCDS being a bugger?
    Tom
    2007 1.9 Audi A3 8P Sportback
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,571
    Are you in module 09 - Cent Elec?
    What version of VCDS are you using?
    I know you can't add these to 09 onwards, but thats because there isn't even a Long Coding Helper available.
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Apr 2011
    Doncaster
    68
    Yep I'm in module 09.
    Using Version 10.6.2
    Tom
    Apr 2011
    Doncaster
    68
    I should be able to just type the values in if somebody gives me the correct ones right?
    Tom
    Apr 2011
    Doncaster
    68
    After a lot of digging it seems that I need an updated board as mine isn't a high end one. Does anyone know which board I require? Or can I update my one with the high end details?
    Tom
    Apr 2011
    Doncaster
    68
    Finally found what I was looking for in this thread Link
    Anyway thought I would post this up in case anyone else ever needs it
    Looks like I need a new module to get these lights to work!
    Tom
