EM TuningAH Fabrications
    imported_trident21
    Removing the rear window wiper...
    Has anyone done it? What did you do with the cables to the engine? what did you fill the hole with? and how did you plug the pipe for the splasher? Will there be any fault message if you cut the wires? [img]/ubbthreads/images/graemlins/book.gif[/img]
    Re: Removing the rear window wiper...
    Why would you ever want to remove the rear wiper...
    steeve's Avatar
    Nov 2004
    Far Corfe
    545
    Seems an odd thing to want to do. Why?
    imported_trident21
    Im odd.. I never use it and dont like that it has its own life when you put in the reverse. And I also think that it might look good without one..
    steeve's Avatar
    Nov 2004
    Far Corfe
    545
    If you do remove make sure you can replace it when the time comes to sell, it will devalue your car......
    imported_trident21
    I always do...
