EM TuningSky Insurance
Results 1 to 7 of 7
    dsg
    Jun 2009
    99
    2.0 tdi 140 coolant issue
    hi guys,
    recently the coolant light appeared on my dashboard when i started it up. so i popped the bonnet and the coolant levels seemed fine. i was baffled. so i turned the engine off and back on again and the light didnt appear si i drove the car as normal. now and again when i turn the car on it appears although i havent been driving the car much as im getting rid of it. just wondering what you guys think could be the problem as the coolant level in the tank seems spot on? ive also noticed the car seems to be a bit smokier than normal if you really look for it.
    tia guys
    ian
    dsg
    Jun 2009
    99
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Could be the coolant level sensor. There are two metal bolts in the coolant expansion tank which tend to get oxidised, try and scratch them with a knife. Just in case I'd scan the car with VCDS.
    VCDS USER
    27,013
    Unless you're seeing a drop in coolant, then as above, check coolant sensor, also check oil cap for any mustard & any drop in oil dramatically.
    Jun 2011
    Hi, as above the level sender in the bottle is the most likely cause. Audi supplies cartridges to go in the bottle to stop the oxidation from happening.
    Kriminal's Avatar
    Bristol
    177
    Quote Originally Posted by SAiLO View Post
    ^ as above. I had the same issue with my previous TT - a simple scraping with a knife done the trick.....had the car four years and didn't get the problem again, so hopefully this'll save you your pennies to spend elsewhere
    dsg
    Jun 2009
    99
    cheers for the replies guys ill have a look now at the sensor
