EM TuningBadger5
Results 1 to 22 of 22
    Jun 2008
    south wales
    230
    AUDI S3 8P STEERING RACK PROBLEM - HELP!!!
    Hi guys
    My steering rack on my 2007 s3 is fudged and i need a new one. I've been offered one second hand off a low mileage 2010 car. will this fit my 2007 s3 ok?
    Thanx
    Jun 2008
    south wales
    230
    ANYONE???????
    poli84's Avatar
    Nov 2010
    Melbourne. Australia
    430
    I installed a 2007 S3 steering rack into my old 2006 A3 with no problems at all.
    As I am a consultant to Audi Auastralia, I spent a lot of time discussing this issue with the National Service Manager and was advised that you can install a newer rack but not an older one.
    The below is information received from him which should answer your question pretty thoroughly.
    I was advised (I ended up finding a wrecked S3) that if I was to buy a new rack, it would be part# 1K2 423 055J to fit my old 2006.
    MY10 S3 Sportback - 6Sp Manual - Sprint Blue
    REVO Stage 2+ /
    Forge Twintake / 3" Miltek Hybrid DP/​ Autotech HPFP
    Bilstein PSS10
    / H&R 10/12mm Spacers / BFI Dog Bone /EBC Yellowstuff
    BUILD THREAD
    Jun 2011
    Melbourne
    230
    Good info poli. Sadly most of Gen2 steering racks will be replaced at one stage or another i believe. I had a new one installed and it does feel different than the old one. more sensitive and more rd feel. my original one started squeeking at low speeds and turns. I would go back to Audi and insist they pay for at least the part or the labor. this was a faulty part with so many reported issues and breakdowns yet they never did a recall. If they want a list of how many people suffered from this then i reckon we can give them at least 50 names!!
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Audi will give you a couple of hundred discount on a new rack if you hand in your old rack.
    Jun 2008
    south wales
    230
    Thanx for the advice poli84. Looks like it should fit. I've already tried audi and they didnt wanna know. I've been offered a 2010 rack for £100 and it's covered just 8k, so i'm just gonna go with that i think. Thanx
    poli84's Avatar
    Nov 2010
    430
    Shouldn't be an issue.
    Good luck, let us know how you go.
    REVO Stage 2+ /
    Bilstein PSS10
    BUILD THREAD
    Oct 2008
    888
    How much are these new?
    27,114
    New are £930 odd, but be warned, the gen 2/3 required looms aswell, so check with parts department as it shows them a note when they click on the item, all racks are being replaced for gen 3 if they come in for them now.
    8P racks are synonymous for issues, especially the creaking noise & the clonk you get on full lock, cant remember if was left or right lock, think was right, hence why audi have untold stocks of these in stores, last time I checked there were 2-300 odd which with parts is fairly unheard of unless its a service item lol.
    I would bug audi for goodwill as they know of the issues for sure.
    Oct 2008
    888
    Since mine is now just out of warranty how do you think l would stand if l brought this to their attention and was found to be indeed the rack.
    27,114
    You stand a better chance than most I'd say, they have a 5yr cut off afaik & when pressed on something they're aware is a known issue, that they wont openly admit, they will offer something, but its a bit pick/mix with dealers, as some are just pita's, but some are very understanding & will ask audi uk what they can do.
    Khufu's Avatar
    West coast of Scotland
    5,693
    were gen1 ok? I'd hate to think mine is going to go somewhere down the line...
    Oct 2008
    888
    Mines a Gen 1. l noticed this creaking or it sounded like fluid gurgling some time ago, well over a year. l was told it was the haldex. Or a top mount needing greased. lve no idea how to get access to a top mount.
    27,114
    Remove shock & its at the top lol
    Fandango80's Avatar
    Oct 2004
    Poole, Dorset, UK
    71
    I just had my 07 s3 rack replaced by audi under warrenty. My mate works there and he said that its a 2010 rack but they have to plug the car into their diagnostics to program it. The ECU apparently talks to HQ in germany and registers the rack with the car. Without this, it apparetly wont work. There are also settings which makes the rack perform differently. He set mine up on an Rs3 program and amazingly it made absolutely no difference to the feel of the steering
    Thought id let you know about the programming incase it is a problem.
    Cheers.
    Jun 2011
    Melbourne
    230
    Quote Originally Posted by dc240969 View Post
    Dont believe that crap, thats what they told me too and supposidly followed AUDI instructions and "fixed" the issue by lubing the strut tops only for it to happen again 24 hrs later.
    poli84's Avatar
    Nov 2010
    430
    This is what has happened to me too.
    I've already at it at Audi with the creaking problem and they dismantled the suspension and lubed the strut tops.
    I'm waiting for it to come back again. Although I'm a little worried that if it happens after I've installed the ARB's, they will blame them for the creaking noise.
    REVO Stage 2+ /
    Bilstein PSS10
    BUILD THREAD
    27,114
    Just re-read this, the top mount isnt 100% sealed but certainly isnt something that you can whack loads of grease into, if its got road grit in, dust etc which happens often it could over a period of time cause wear on the internals & make them loose, only when I did my suepnsion upgrde did I realise mine wernt in good condition, hence swapped out.
    Quote Originally Posted by NCRAW View Post
    +1
    Quote Originally Posted by poli84 View Post
    Creaking issue is nothing to do with the struts, typical audi fob-of, its from the rack itself.
    kaitracid's Avatar
    Apr 2010
    12
    Hi, I have problems with servo steering. Most of the times, servo doesn't work and the servo witness on the dashboard is mostly on than off. Is it the power steering box or another thing (like ECU)? I am searching for a SH power steering box, but can't find one with exactly the code that I have on mine. Oddly, I can't find this code in Etka. I will attach a photo so you can see, there are two codes, 1k1 909 143 J and 1k1 909 142L. The A3 is from 09/2003, so it's first generation A3 8P.
    Can you tell me which steering box would work? I am also asked if I have 2 or 3 wires to connect it, but I have no idea, now I drive the car in this condition.
    a3 2.0 tdi BKD 103kw
    27,114
    I have a rack for sale, of an early BKD aswell.
    The part number is actually stamped into the metal somewhere, that is not the rack part number you've shown.
    2.0T Quattro
    Jun 2011
    Nottingham
    78
    dam heard that creaking on mine when you turn the wheels while stationary. looks like i be going to audi to get ripped of aswell my car is 2005 way out of warranty only 30k on clock but i guess they will still say wear and tear
    Audi A3 2.0T Quattro Lava Grey 18" Dezent light pack Shark remap stg 1
    davc's Avatar
    Foursprung Duck Technik
    Jan 2013
    Caledonia
    217
    Mine started making the same gurgling noise last week, and I've got a squeak when turning at low speed. Me thinks the recon'd rack I got this time last year is goosed
    MY'09 S3 Sportback |Gloss Black Mirrors |Buckets |Black Optiks |Open Sky |Light & Rain Sensor Pack |CH/LH Lights |RNS-E & No Highs No Lows it must be Bose |
