Badger5AH Fabrications
    WWW.APR-REMAPS.CO.UK
    Jan 2011
    DONCASTER
    222
    S3 SPRINGS ON A TDI SLINE - Would they fit?
    Im wanting my car a bit lower but i domnt want to loose the plush ride it has the cars only two years old and feel nice and tight so i dont want to ruin it by slamming it to the deck, the golf tdi mk5 i have has eibach springs and its crashy so i dont want that on the a3, thought the s3 springs may fill the void?
    Anyone done it?
    thanks
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    i wouldnt risk it, the TDi engine is a fair bit heavier then the petrol engine so the springs wont match the axel weight or the damper rate so there is a good chance it will be all over the shop
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
    eddyd's Avatar
    May 2010
    94
    If it's a quattro then the afaik the springs will fit.
    H&R use the same lowering spring kit in the diesel and petrol quattro(3.2 and 2.0).
    The shocks won't be matched would be my worry though but someone on hear has fitted s3 springs to a 2.0T quattro.
    Jan 2011
    DONCASTER
    222
    hmm might get some springs then whats best ones h&r or eibach or other?
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    If your car is an S-line TDI you will need to get proper lowering springs or much better a proper coil over kit if you want the car lower. Lowering spring on standard shocks are not a great idea. The lower the lowering springs the more harsh the rider.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
