Badger5EM Tuning
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By NHN
Thread: Anyone In The Northwest With Vagcom? Rns-e Help!
    ian ditch's Avatar
    S-Line Lover
    Mar 2009
    Warrington, Cheshire
    19
    Hi All,
    I replaced the original Symphony II stereo with a Rns-e unit about 12 months ago. Ever since the base seems to be of very poor quality compared to the old Symphony II.
    At the time of the install, i read up on what i needed and ordered the correct harness and ensured that the pin was grounded etc.
    I think that the Rns-e unit needs to be told that the car has bose and the relevant settings altered to suit via the vag-com software.
    I'm prepared to pay if there's anyone close enough to me - I'm in warrington, cheshire.
    Audi A3 8P Sportback 2006 2.0TDi 170 Sline with trip-tronic
    My Photobucket Gallery: http://photobucket.com/ianditch
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I have Vagcom and i am in Crewe, i can help you if you know what needs doing on vagcom.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    I'm manc! Holla if you need.
    ian ditch's Avatar
    S-Line Lover
    Mar 2009
    19
    Hi Robin, thanks for the reply
    I don't know what needs altering via the vagcom, and to be honest, i'm just assuming that this is what is required to fix it.
    but google is my friend and i'll take a look around and let you know.
    many thanks
    ian ditch's Avatar
    S-Line Lover
    Mar 2009
    19
    Quote Originally Posted by N8 View Post
    Hi N8, do you know what needs doing via the vag com??? would save me googling it. Where abouts in manchester are you?
    27,096
    Possible wire needs moving on the loom/connector & then enable sound system in module 37 or 56, change it to a 9 for Bose, so it should read something like xxx9xxx, iirc, where x = others numbers, sure someone will correct me if I missed a trick as going from memory
    The bass on symphony I find OTT anyway & even with Bose enabled & wired correctly it will still sound less substantial than the symphony system, so you know now
    ian ditch likes this.
    ian ditch's Avatar
    S-Line Lover
    Mar 2009
    19
    Thanks for this NHN, very informative.
    I have the bose harness with pin 7 grounded so i'm sure the pins are fine.... i cant see any other pins that may need moving??
    reading Audi Radio/Navigation System (RNS-E) - Ross-Tech Wiki, what you have said does make sense.
