EM TuningMonster Motorsport
Results 1 to 11 of 11
    Cardiff, United Kingdom
    377
    Voice control and Bluetooth problems...
    I recently installed Bluetooth in my 2008 A3 as I had it in the previous one and found it useful. The problem I have now is this, everything was installed properly and today I had it coded. I was told that everything is working fine and coded properly but I cant pair with it at all. I have an iPhone 4 and it just searches and searches but wont find anything. The RNS-E just shows the usual your phone may not be connected properly screen and goes no further than that.
    Tried with my girlfriends phone and that too cant find it.
    The guy at the garage said he set it so it was always discoverable, not just for x amount of minutes.
    The other thing was that in my 07 plate A3 I used to be able to press the button on the steering wheel and say "Select Name" or whatever I wanted to do. Now I thought by installing bluetooth I could do this again but I cant. Do I need a seperate unit to enable voice commands or should that work with the bluetooth unit installed?
    Sorry about only really being able to ask questions and not being able to answer many you guys put up...
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    Is it a OEM bluetooth kit? if so then the voice commands should be ok as i have them on mine. With the bluetooth issue to have check that it is in fact set to discoverable and also check the bluetooth antena is properly plug in on the box.
    Ron
    Audi A3 8P2 2.0Tfsi S-Line Special Edition Bluefin
    3dr Mauritius Blue || Full Leather|| BOSE || MFSW || Auto Lights/Wipers || Auto Dim Rearview Mirror || Heated Mirrors
    Mods: S3 Aluminium Pedals || S3 Vents || 2010 RNSE || OEM Bluetooth || Dension Gateway 100 || MY09 Rear Lights || Single Xenon Headlights
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Sorry to hijack the topic...
    I have the kufatec fiscon installed in my a3 but cant get connected to it with my iphone 4. I've tried a few 3g iphones and some nokias aswell and none can connect. The bluetooth is discoverable but no phones can pair with it successfully.
    Any ideas?
    377
    Quote Originally Posted by BlueSpark View Post
    Yes its all genuine Audi parts, brand new not second hand. Its a pain in the butt, I just want this car to function like my previous A3. When I press the button on the wheel it doesnt do anything not even the beep like my previous car.
    377
    Not sure if this helps but heres the unit itself, the connector on the cable is locked firmly into place as is the antenna or ariel thing whatever it is.
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    Quote Originally Posted by moag View Post
    Any ideas?
    Hi Moag, try clearing your recent call history list on ur phone and connecting. My HTC wouldnt make calls or display phonebook until i did this.
    Ron
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    I am pretty sure that the bluetooth module is separate from the voice command module. The bluetooth will simply enable bluetooth calling, and you would need the voice module to have voice activation. Nigel (NHN) should be along soon enough to confirm... or just PM him.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Feb 2009
    Aberdeen
    2,490
    Quote Originally Posted by itwasntme187 View Post
    Bluetooth help.
    Sounds like they are actually two different "modules" (bluetooth and voice activation) and NHN can get you both.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    Gave that a go, but still no luck! Where do they fit the BT modules, I've heard its under passenger seat?! Cant connect to it with my laptop either to update software. Not sure where to go from here
    Nov 2008
    389
    Quote Originally Posted by welshwoody View Post
    Looks like everything should be ok. Do you have access to VCDS to check if you can communicate with the module? Just done the same install in our A4 - bluetooth, RNS-E and steering wheel all need a little bit of coding. I think I had to do an adaption on the cluster too for the DIS so i wonder if your guy hasn't coded everything needed? That said, it should still show up on the bluetooth when you search with your phone as long as it has power.
    26,720
    Quote Originally Posted by MartayMcFly View Post
    Bluetooth help.
    Thats not what I said tbh, I said I could install SDS, that requires wiring, coding & fw updates to mk1 rns units & mk2's I dont do anything with firmware, just supply an sds unit.
