Chris NottBadger5
Results 1 to 15 of 15
Thread: white smoke
    May 2011
    white smoke
    Hi, Ive not long had my Audi A3 2.0TDCI and have notice when pulling away im getting excessive white smoke from the exhaust, just wondering if theres anything common that causes this, or any idea what it could be? it doesnt appear to be using oil or coolant!!
    Lizard-Racing's Avatar
    DTM
    Apr 2011
    Hampshire
    151
    Does it happen when its hot or cold? All the time or first 5 miutes? Only first thing in the morning? Is it deffo white smoke?
    Alex
    2005 DTM|Quattro|Phantom black|HTA3076 turbo|Pag Parts turbo manifold|INA Engineering custom 8 injector manifold|Custom Garrett 900hp intercooler|Mahle Motorsport 83mm forged pistons|IE Tuscan forged rods|Autotech HPFP|Tial wastegate|S3 Injectors|3" Downpipe and full stainless exhaust|Stage 3 Southbend clutch|AP Coilovers|Ultra Race strut brace|H & R ARBs|Forge 6 pot calipers|Bi Xenons|Multifunction steering wheel|Memory seat|Cruise control|Power fold mirrors|Black 19" Cades Berns|235/35 Toyos
    May 2011
    Happening all the time but noticing more when warm, could be sitting in traffic, pull away and smoke the car behind out and the pavement. Its White/blue smoke!!!!
    DTM
    Apr 2011
    Hampshire
    151
    Are you sure that you are not loosing coolant? Sounds like turbocharger to me.
    May 2011
    Pretty sure im not, but only have the car a few days. Taken it back to the garge where i brought it from, and theyre going to look into it. Had noticed aoil leak from the back of the head by the exhaust manifold, someone i know thinks it may be an oil gallery leaking, which if leaking into the bore could also be causing the smoke issue. It drives fine other than the smoke, but turbo could be a possiblitly but guess its down to the garage to sort out.
    DTM
    Apr 2011
    Hampshire
    151
    The turbos are easy to change on these can be out and tested within a couple of hours.
    May 2011
    I let the garage know, maybe something they can look into, mite be best for them in the long round to maybe even send it to Audi.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    white smoke = turbo nackered
    ​She is back on the road yay!!
    27,114
    TBH atm pointing to turbo if its pouring out the exhaust, if it was an oil feed line loose or the small return pipe then it wouldnt come out of the exhaust imho, more from under bonnet with burning oil smell through the vents, but certainly return to the garage for testing.
    evocos's Avatar
    Mar 2009
    Derbyshire
    515
    Exactly what mine was doing before the turbo went
    A3,tdi sportback,remaped,custom turbo back zorst,green filter,19"speedlines,airlift ,xenons,votex side skirts & spoiler,smoothed sline front,s3 back bumper, s3 mirror's,red nappa,s3 vents,pedals, gearknob,fbmfsw,opensky and more. ow and an RS4
    For sale ....dolphin grey tdi 2006 front and back bumpers with grill,fogs etc,mirrors,sportback standard rear lights and mudflaps.
    All going cheap lol
    Also my mint 19 x 9 polished and red faced speedlines,with all good toyo t1rs,coming soon :o)
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    561
    If its doing it on the tick over its normally the turbo if its light grey smoke,white smoke can be air leaking in to diesel or condensation in the fuel,but would say turbo if doing it when sat in traffic,my golf with a milltek on used to store condensate over night when cooling then poor steam out for first few mile but that was all the time
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Jun 2011
    Hi All, my 02 A6 1.9TDI SLine is blowing alot of black smoke, 1st noticed about a month ago. Started it when cold and tried to take off but ended up stalling it, thought it was operator error but tried taking off again and same happened, so when I started it again I said I'd rev it a little but there was very little response. Put the peddle to the floor but the rev counter was very very slow coming up. When going up a small bit of an incline it seemed to struggle and I even had to stop half way up the incline to clutch it and try to get the revs up a bit but again very little response with alot of smoke but when it hit 2500 rpm it took off as normal with a plume of black smoke. This is happening more regularly now, happens when both cold and hot. When it does happen in 1st or 2nd gear there seems to be a hell of alot of black smoke. At 1st I was thinking it was the turbo but there is no whining noise and seems to work fine over 2500rpm expect for the plume of smoke. Tried injection cleaner also but no joy. At this stage I'm uneasy pulling out onto a roundabout or main road because if it happens then it could get me in a bit of trouble. I'm wondering did this happen to anyone here or did anyone hear of this happening.
    Thanks in advance.
    Apr 2010
    149
    sully your in limp mode. thats why you have no power until 2000+ rpm , u need to have it scaned on a VCDS n it should tell you the fault.
    27,114
    Probably running lean, maybe a boost pipe has come of.
    Jun 2011
    Thanks for quick reply zedzo, will have to get it checked out.
