Results 1 to 7 of 7
    Sep 2009
    22
    After lowering car problem
    Hopefully can get an answer here
    Earlier today i changed my standard springs to eibach sportline while on the passenger side the drivershaft came off, so took the CV joint off re-greased and set back into place just hoping i havent made a mess of it anyway I finished the job their is no rubbing to arches but when i get to around 30mph+, its shaking quite rough.
    Will this just need alignment or what else should i be looking for here car is a 2.0 TDI 2004
    Brian
    Mar 2011
    Wolverhampton
    125
    No way would the tracking make it that bad just from lowering it. I would definately suggest that you take it to a garage to wack it on a ramp and drive the car whilst somebody is underneath, if it makes a noise, you know its the dirveshaft.
    2006 A3 2.0 TDI Quattro S-Line l Team Heko Wind Deflectors l Celtic Tuning Remap l Rear De-Wiper l Pipercross Panel Filter l
    After a Passenger Xenon Headlight for A3 8P. No ballasts required. PM ME!!
    Khufu's Avatar
    West coast of Scotland
    5,693
    I'm not sure about the A3 but on other cars the danger could be when the drive shaft came out the needle bearings could have become displaced (at the gearbox end). We had this once on a Peugeot IIRC.
    27,121
    Its more than likely your driveshaft is the tripodic type on the 04 A3, its called tripodic because it has 3 corners as such with ring bearings is only way I'd describe them, that sit on each corner & gives it the flexibility it needs, this pushes into a socket as such on the inner part of the shaft nearest to the box/engine.
    So its possible when you slipped it out, maybe you've dislodged one of the ring/bearing ends & its loose inside the housing, I would get it up in the air & have a play to see if there is any serious play on the inner joint, if so then need to remove it & check the shaft end inner to see if anythings amiss.
    Sep 2009
    22
    thanks everyone for your help
    thats great NHN it was that part that came away there was 3 corners which i slid back into the housing is it poss it wasnt far enough ?
    il hopefully get it apart again today should i remove it all from the box and piece back together or just repeat process of when i lowered the car removing strut etc
    thanks
    Brian
    27,121
    TBH its self adjusting back & forth, thats the point of the inner socket imho so its got some movement if need be rather that a solid joint with bearings, good idea tbh.
    But if you hadnt put it in the socket correctly, I'd believe it would be extremely noticeable just moving of, not just corners.
    Did you remove the shaft also from the hub end as sometimes this isnt seated properly & hence issues, mate had this after a cowboy garage did his upgrade of suspension, was exactly that, shaft badly fitted on the spline hub end iirc.
    Given your issues, I'd remove the whole thing & check for any damage to the bearing ends, when you do these jobs you're supposed to hang the shaft up somehow so there is no weight on the shaft itself & no warp when refitting, which as much as I find it hard to believe as they're hard/thick as hell, but they're fairly heavy so any stress on the joint ends could damage the bearings hence looseness & issues reported.
    Sep 2009
    22
    That's great il give it ago.
    Once I move off and at slow speeds it's fine no shaking no grinding/rubbing noises when on full locks :s
