has anyone came across this i start my car and it idles fine [800]rmp no warning lights on . start to drive for a couple of minutes and all is fine then it start to feel sluggish dip the clutch and idle speed is at 1000 rpm and wont go any lower when sitting stationery there is misfires comming from rear silencer . if you turn of the ignition and re start idle goes back to 800 rpm and the engine runs as sweet as a nut [no misfire] .you can rev engine and it seems fine only when you drive the car for a few hundred yards it happens again its been doing this the last couple of days ... it dont have access to vag com tried my works bosch reader which said error memory is clear .... car is not on limp mode just feels dour to drive lack of power from idle then it will pick up any ideas
