Monster MotorsportChris Nott
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    Coleraine, Coleraine, United Kingdom, United Kingdom
    512
    Wheel Bearings :(
    Ok yeah so my car has been making weird pattering noises when steering to the right and has gotten louder these past few days so I discovered that it was my drivers side wheel bearing which is bad.
    I Jacked it up and there is some play in it also.
    Is it a big job to replace? does anyone know a rough figure to buy new bearings?
    cheers
    May 2010
    London
    334
    Bearings are around £80 - £90 each, plus around £100 for labour. I did one of mine last year for £175
    Its a couple of hours to replace, but dont know how hard it is.
    There are 2 different bearings 3 or 4 bolt fixings, make sure you get the right one (i dont know how to check but IIRC I used the 4 bolts for my A3 2.0 TDI 2005)
    holderd's Avatar
    Sheffield
    40
    I took mine to my trusty local independant. As above the parts are £90-£100 (depending on front or back) and the labour was about £50 for the replacement of one of the rears on my 2005 (I'm pretty sure the front costs more...).
    Depending on where you take it i'd make sure they have got the right tools, if I remember correctly it was a VAG special socket that was needed. The chap that did mine didnt have one but luckily knew someone that did.
    2006 Audi A3 1.6 SE 3dr 102bhp
    supanova's Avatar
    A3 2.0 TDI SE
    Apr 2010
    512
    Does anyone know which type i need? Im looking to order online tonight so that hopefully ill get it faster than call around tomorrow and wait for them to have to probably order it in.
    my car is the audi A3 SE TDI reg in 2003 but its the mk2 model.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    If you have the tools then it's an easy job. I replaced mine not so long ago on the front passenger side. Bearing was about £130. You will need some spline drive sockets and a breakers bar.
