AH FabricationsSky Insurance
Results 1 to 8 of 8
    Apr 2008
    98
    Bkd pd 140 problems can anyone help ?
    Hi
    Wonder if anyone can help with a problem I am having with a bkd pd 140 vw mk5 golf on 55 plate (same engine as a3)
    Have had the car remapped since purchase 2.5 yrs ago all running fine. Over last month the engine has not felt like it is running right. No fault on vag com.
    The car is fine if driven with large throttle on off movements but if the car is driven lightly on the throttle or on cruise control the car pulses on / off. Ie in 3rd gear at 30mph on cruise on the flat or slight decline in road it is if car does not know what to do , power on or off (also been described as bucking) This is also the case when using the pedal. If is usually around 1500 - 2000 rpm.
    I have had the remap removed which has made it worse !
    I have fitted new egr valve. Also tried part blanking it per a forum tip.
    I have tried a new MAF sensor , still same.
    Fitted new filters, checked pipes for leaks etc.
    I have taken to remap dealer but does not know where to start but tried throttle pedal, still same.
    I have paid vw to diagnose fault but are just blaming remap and want £1100 for new ecu before will do anything else !
    I have checked injector valves with vag com all seem ok.
    Can anyone help ? Anyone know anywhere in South Yorkshire could trust to have a look or offer a little direction with this fault ?
    Thanks in advance.
    Mar 2011
    Wolverhampton
    125
    Okay, firstly, was the ecu remapped via the obd port,or was the ecu piggy backed? Start with the basics. I would possibly recommend a dealer remap with the factory map to completely eliminate that. Daft as it sounds, it couldnt be clutch related or like the brakes are seized?
    2006 A3 2.0 TDI Quattro S-Line l Team Heko Wind Deflectors l Celtic Tuning Remap l Rear De-Wiper l Pipercross Panel Filter l
    After a Passenger Xenon Headlight for A3 8P. No ballasts required. PM ME!!
    Mar 2008
    Bradford, WY
    788
    Common faults, maf, map/boost sensor, vac leaks, seals in intercooler pipes, n75 valve. Sometimes injectors. Any other problems? Smoke? Loss of power? Limp mode? Maybe even turbo. You should log it with vag com or get your tuner to.
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    Apr 2008
    98
    Is a motorsport remap by obd and has been running perfect for 2.5 yrs. Brakes are like new all round and car has had dmf and clutch replaced not related to the fault. The fault is definitely with the engine not knowing what to do. Vw tech seemed to think to do with egr system but no difference with turned off.
    Mar 2011
    Wolverhampton
    125
    Hmmm difficult to say then mate really, could be a number of things. I'v had similar problems on cars and its been fuel related. It hasnt had a non genuine fuel filter has it? Iv heard stories of on vag engines, the glowplug tips break off and cause low compression on the cylinder in question (no fault codes).
    Apr 2008
    98
    New turbo was fitted over yr ago , no other faults apart from judder under similar conditions as if car is missing. Apart from that car running good no loss of power , no smoke , mpg unchanged, starts perfect. Have done some logs but nothing standing out to me.
    Mar 2011
    Wolverhampton
    125
    Okay, last thing then. We had a 2.0 sdi at work with the same fault. You disconnected the egr solenoid or the maf sensor and it ran like a dream. We fitted a new solenoid and reset all adaptions and never had a problem since.
    jerseypaul's Avatar
    May 2011
    Jersey - Channel Isles
    242
    I had pulsing on a neutral throttle turned out to be an O2 sensor.
    2012 RS3 Daytona grey - VW T5 Transporter 4motion 130 - VW UP!
