AH FabricationsSky Insurance
    Kash3838's Avatar
    May 2011
    Cardiff
    173
    Thumbs up sd memory card for rns unit s3 2007
    im picking up my dec 2007 s3 next week and wanted to order a couple of memory cards before hand.
    what type of card do i need and is my uit a mk2? seen the posts on here, but now im confused weather to get sd hc or not and also what the max size i should go for. any help would be appreciated
    161
    2007 has a MkI, so it can only take standard SD card (not SDHC), thus its max memory is 4GB (more likely 2GB available).
    Kash3838's Avatar
    May 2011
    Cardiff
    173
    cheers buddy!
    Nov 2004
    94
    Yep - I got 2x2Gb SD cards and use MediaMonkey to sync my music and playlists to them - works a treat
    Oct 2009
    73
    Yup the 4gb card I found is a bit pointless because even if you find one in SD there is also a file/folder limit for the RNS so you can't fill it anyway
    Kash3838's Avatar
    May 2011
    Cardiff
    173
    Cheers I bought 2x 2gb of eBay both for 8 quid delivered.
