JMB RetrofitsSky Insurance
Results 1 to 12 of 12
    Feb 2011
    535
    Hold AUTO button for 2 seconds to sync temp...
    ...but it then syncs my (the drivers) temp to the passengers!! How does that make sense? haha
    Should it do this or is there a way of changing it?
    The missus always leaves the car with her side on 25+ whereas I run hot and always have it around 18 so it would be nice to quickly match her temp to mine.
    WANTED: S3 Side Skirts (3DR)
    A3 S Line DSG TDi 140 (56) | Lava Grey | Groove & Drilled Discs | Green Stuff Pads | Eibach Sportline Springs | Eibach Spacers | Full heated leather | RNS-E 2010 MK2 | Rear Parking Sensors | Interior Light Pack | Heated Mirrors
    Nov 2004
    35
    Maybe you have a control unit from a left hand drive car?
    Feb 2011
    535
    Quote Originally Posted by nicksa3 View Post
    Hmm sounds like that could be true.
    So does yours sync the passengers side to the drivers side then?
    Nov 2004
    35
    Yep, the driver's side is the master one, if you like.
    Feb 2011
    535
    Great, something else that has been messed with then...
    Ok thanks - looks like I'll need to deal with it.
    Although you would think that there much be a way of changing this, maybe within VCDS? As it seems weird that Audi would manufacture two different types of unit.
    27,029
    You need to do a basic setting 01 in hvac 08 to make it read the car as a rhd car, if it doesnt work then something is coded on the car to say its lhd, correct this then do basic setting again.
    They dont manufacture 2 types.
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Of coarse it sync's to the wifes side....you obviously have a female car. Next time you buy a car,check the logbook and make sure its a male and you will be fine .
    27,029
    lmfao
    Sep 2010
    17
    my new A3 is the same. it syncs with the passenger side maybe Audi are just getting lazy.
    Feb 2011
    535
    I take it that I need VCDS to find out what is coded as RHD and also to do the basic setting too?
    27,029
    Yesh
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Why don't you just convert your car to a left hand drive? Problem sorted.
